Steam from transmission dip stick tube? - JeepForum.com
post #1 of 6 Old 12-09-2011, 11:49 AM Thread Starter
edwyman
I have a 93 4.0 with I believe a 42re; performed a fluid and filter change and adjusted both front and rear bands.
Fluid level is good, though not as red/pink as I would think, somewhat clear and transparent. Fluid does smell a bit burnt.
Shifting is worse after fluid change than before. Slow to go from stop, sometimes need to get higher RPM's before engaging into 1st. Down shifting is good, up shifting could be a little tighter (I should readjust rear band again).
There is also a slight burnt smell when stepping out of the heep after driving for a few miles. No tranny codes being reported.
A few questions:
1. Why would steam be coming out of the transmission dip stick tube? Is this normal?
2. Is the transmission pump mechanical or electrical?
3. Could the pump be cavitated and now fluid is not getting circulated?
Thanks for any advice!
edwyman is offline
post #2 of 6 Old 12-09-2011, 11:54 AM
PolkaPower
It's not normal. You may have incorrectly adjusted your bands. They are tricky to do. For a simple fluid change only by dropping the pan you will not get all of the old fluid out. I think only around 4 quarts or so. The rest will remain in the system unless you pull your transmission return line and drain it out. You are supposed to do this while pouring fresh fluid in until you see all of the old drain out and new fluid comes out. That way you don't get air into the pump. Keep checking your fluid level. You may not have filled it up all the way. I am assuming you know to check the fluid levels while the motor in on and in neutral after it has reached operating temperature right? Also the color isn't as important as the smell. That burnt smell is a bad sign.
PolkaPower is offline
post #3 of 6 Old 12-09-2011, 01:55 PM Thread Starter
edwyman
Thanks Polka!
Yes, I am checking fluid correctly.
Bands we actually quite easy to do, front one though is tight to get at. Originally adjusted the bands at F: 3 and R: 3; 1st gear engagment was really bad. Now I am adjusted to F: 1.5 and R: 3; much better than before.
Looks like I will be doing a flush and see if things improve...
Anybody else, thoughts?
BTW: this forum is great!!! I have learned so much about my heep in the last few months here.
edwyman is offline
post #4 of 6 Old 12-09-2011, 04:31 PM
bigbill888
You are torquing the bands to 72 INCH pounds and not FOOT pounds, right?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 6 Old 12-09-2011, 05:05 PM Thread Starter
edwyman
Yes, sir!
Actually spent a few hours on a Sunday running down an in. lb. torque wrench - o'reilly, napa, sears, tool town and finally Harbor Frieght to the rescue!
edwyman is offline
post #6 of 6 Old 12-09-2011, 11:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Those sound like the haynes manual recommendations...which are very incorrect.
Band adjustment changed year by year. Follow the factory service manual specifications for your year. allowing for the couple updated tsb's for a few years.
ratmonkey is offline
Trouble with transmission fill tube HighLonesome ZJ Grand Cherokee Forum 8 09-21-2011 08:51 AM
Transmission/RPM Issue - Auto Stick not working????? pigeon620 WK Grand Cherokee & XK Commander Forum 2 06-30-2011 05:32 AM
Can not find Grand Cherokke 2007 Transmission Dip Stick ekam WK Grand Cherokee & XK Commander Forum 13 02-24-2010 10:03 AM
Transmission gear stick panel gets boiling hot!!! kingkong1920 ZJ Grand Cherokee Forum 12 12-19-2007 07:09 PM
Condensation in dip stick tube ? donp ZJ Grand Cherokee Forum 3 12-12-2006 03:01 PM
