steam from radiator... - JeepForum.com
post #1 of 5 Old 03-11-2003, 11:37 AM Thread Starter
MRfire
I have a 5.9 limited, and intermittently, when I'm stopped at a light or just sitting in park - steam will rise from my front end. I notice no problems with the temp gage, etc. Should I be concerned about this?? Thanks for any insight.
98' Grand Cherokee 5.9 Limited
- FIPK
- Mopar ECU
- Kuhmo Ecsta STX Tires
- Roto-tec Cross/slotted rotors
MRfire is offline
post #2 of 5 Old 03-12-2003, 09:29 PM
Swamp Boy
Swamp Boy's Avatar
Temp gauge may be wrong but most likely you need a new radiator cap. Sometimes when they go bad they start leaking and
you get the steam thing.. Keep and eye on coolant level and the resevior if the resivoir is dry this might be your problem.
No mater what radiator cap= cheap
Motor with no water= expensive..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 5 Old 03-13-2003, 10:01 AM Thread Starter
MRfire
Thanks for the reply, I'll replace the cap just in case. Also, I was thinking of getting the 180* thermostat. What benefits will this provide, if any? Thanks again.
- FIPK
- Mopar ECU
MRfire is offline
post #4 of 5 Old 03-16-2003, 01:20 AM
Speedtoy
IMHO..none.
A cooler stat can affect fuel milage/efficiency, and in borderline cooling situations can cause overheating (cycle time thru the radiator is important to cooling, speeding up the cycle time is bad in edge conditions).
Speedtoy is offline
post #5 of 5 Old 03-16-2003, 10:21 AM
Swamp Boy
Swamp Boy's Avatar
I have the Jet racing chip and the 180 thermostat and I live in the heart of hell .. I have never had problems with overheating..and
my ZJ runs great..
Steam out of my grill only after 10 mins jpl ZJ Grand Cherokee Forum 14 02-28-2009 06:04 AM
Steam coming from Engine flyboy14295 ZJ Grand Cherokee Forum 1 10-15-2008 06:50 PM
Radiator Steam martingsa ZJ Grand Cherokee Forum 10 10-05-2007 07:51 PM
Steam coming from front of engine? Rymer25 ZJ Grand Cherokee Forum 7 10-31-2003 01:13 PM
Problem with steam barryt WJ Grand Cherokee Forum 1 02-01-2003 12:46 PM
