Steam from front grill at start up...then gone. - JeepForum.com
post #1 of 6 Old 04-17-2013, 03:37 PM Thread Starter
brewcity1
Hey guys...I have some steam coming from the front of the grill (assume its steam, and not smoke...doesnt smell like anything is burning). It started about a week ago...it only happens for about 2 minutes when I start the Jeep, then its gone. No coolant level drop in the reservoir yet, and the temp gauge stays right at 210. I dont notice any leaks, and there is no weird smells or sweet smells like coolant. No parts swap recently regarding the radiator or hoses either. It does go just above 210 if I am sitting in traffic, but then right back to 210 when I start moving at a good pace.
Any idea what the heck is going on? I searched the forum for "Steam" but couldnt find anything related to my issue. I am totally stumped!
Thanks for the help on this...I appreciate it.
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #2 of 6 Old 04-17-2013, 04:23 PM
T-nave
Does it do this on start up when the motor is cold ? If so it isn't steam b/c the motor isn't hot enough to create steam. Have you got under it to see if there is any coolant anywhere? Mine didn't really have any "noticeable " leaks until you looked under it. It was so slow that it would take a while to notice a drop in coolant. When I took the radiator out I couldn't believe it was still in one piece.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline
post #3 of 6 Old 04-17-2013, 04:28 PM
Foundrydude
Most times I've seen that it's either
Underhood exhaust leak (cold weather)
Or a weeping radiator that's growing a small wet spot overnight, but not leaking enough to hit the ground yet
Foundrydude is offline
post #4 of 6 Old 04-17-2013, 07:29 PM Thread Starter
brewcity1
It does do it on start up...like this morning.
Now you have me worried something is burning!
I did check for coolant, and didnt see any. I'll let it run for awhile, and see if I can spot anything or smell something distinctive.
post #5 of 6 Old 04-17-2013, 07:45 PM
Foundrydude
A valve cover leaking onto an exhaust manifold can also create wispy smoke on first start of the day
post #6 of 6 Old 04-17-2013, 08:12 PM Thread Starter
brewcity1
OK...I'll check that as well....thanks a lot for the help with this.
