Startup vibrations and more - JeepForum.com
post #1 of 1 Old 05-10-2012, 07:16 AM Thread Starter
2000wj_al
Hey guys,
Jeeps are great, don't get me wrong. But boy, they sure are sensitive.
Here is a list of problems i've had since i first purchased it:
  • Checked the OBD, code 43 appeared
    (misfire in the cylinders)
  • IAC went bad, replaced
  • Battery went bad, replaced
  • Replaced spark plugs (2-3 months ago)
  • Exhaust manifold cracked, needs to be replaced
  • Exhaust system needs replacing
  • Want to replace the tires for all terrain
  • Shift solenoid (from what dad told me) needs replacing, shifts late from 1st to 2nd
And now, the check engine lights on again, Checked the OBD, code 43 again?
When she starts, the moment she does, she'll vibrate a little. It seems to be getting worse, but not by much. Any ideas of what it is?
2000wj_al is offline
1997 zj , check engine light , exhaust manifold , OBD II
Mysterious Startup? NewJeepFever ZJ Grand Cherokee Forum 3 12-24-2008 04:05 PM
Help with startup idle ProductUser ZJ Grand Cherokee Forum 6 11-18-2006 12:28 AM
Startup Question Ex-Repoman ZJ Grand Cherokee Forum 10 11-07-2005 04:50 PM
Startup after sitting for 6 mo? Peter ZJ Grand Cherokee Forum 4 10-11-2005 09:30 PM
hi rev on startup sharpe84te ZJ Grand Cherokee Forum 4 08-19-2004 02:41 AM
