Starts, then shuts off - JeepForum.com
post #1 of 4 Old 01-31-2009, 10:59 PM Thread Starter
rnfuentes
1994 XJ Cherokee
My 1994 jeep grand cherokee laredo v8. Sometimes shuts off right after it starts. I had a similar problem a few months ago but was resolved after I put in a "new idle air control valve". What could my problem be?
Recent work consist of: tune up, new fuel (filter & pump).
rnfuentes is offline
post #2 of 4 Old 02-02-2009, 01:29 PM
skunked_once
Could be your security system. Be sure it's working properly. Mine did this once and I had to lock the doors and then unlock the passenger door. There are several threads on this user-friendly security system. Good luck!
skunked_once is offline
post #3 of 4 Old 02-02-2009, 01:41 PM
craiger28
Hello. I had this same problem recently with a 97 ZJ 4.0L. I tried the trick where you put the key in the drivers door and turn the key back and forth, it didn't work. I called a buddy of mine that works on Jeeps and he came out with his computer and reset the ECU to get it to work again. It had a bad battery and went dead and the alarm turned off the car once you started it, it would shut off right away.
craiger28 is offline
post #4 of 4 Old 02-02-2009, 01:52 PM
alivenkickin28
it can be the idle air control again or your security -- try unlocking the jeep in the passenger side door or the tail gate and see if that stops it.
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
4.0 shuts off fullstrut12 ZJ Grand Cherokee Forum 3 08-16-2009 06:36 PM
4.0 Jeep shuts off while driving, sometimes backfires then shuts off. Help please!! PhillsJeep ZJ Grand Cherokee Forum 10 08-13-2009 07:29 PM
AC shuts self off on hot days RedHot-30 ZJ Grand Cherokee Forum 6 05-23-2009 11:24 AM
Jeep Shuts Off?!?!? Need Help tayoh ZJ Grand Cherokee Forum 10 08-09-2005 09:20 PM
Engine Shuts Down falcon25c ZJ Grand Cherokee Forum 8 02-08-2005 08:15 PM
