Starting Problem - JeepForum.com
post #1 of 6 Old 07-30-2006, 12:17 PM Thread Starter
Chuck831
Starting Problem
Ok, I'm getting ready to give up. I have a 2001 Grand with the 6 cyl. Today the remote door locks worked and unlocked all the doors. When I started the vehicle it seemed to start for a moment then just died. Then I turn the key nothing happens. It doesn't crank. There is a fast clicking under the dash even when the key is out of the ingnetion. When you turn the key to the on position none of the gauges work, radio doesn't work. Fuses seem fine. The seat belt light works fine. I don't think it is the battery cause the battery isn't that old.
Could someone give me some ideas.
Thanks.
Chuck
Chuck831 is offline
post #2 of 6 Old 07-30-2006, 03:29 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If itís the original battery than it is old. If it were newer than I would say the battery posts.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 6 Old 07-30-2006, 03:44 PM
driabyor
driabyor's Avatar
1994 ZJ
battery
cables
corrosion
My battery cable that goes to the fuse block broke . killing all power to the inside of the vehicle... I used a lawn mower battery cable , attached one end to the battery bolt then the other to the fuse block, That was a temporary fix.I have now replaced the starter cable end with a different type to make it look cleaner, than just the lawn mower cable attached to a bolt. I might see if I can get a pic
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 6 Old 07-30-2006, 03:52 PM
John in MA
1994 ZJ
First thing I'd check is the battery. Jump it or charge it. But the clicking with the key out sounds strange.
John in MA is offline
post #5 of 6 Old 07-30-2006, 04:56 PM
DSMtuner
daaaamn...same thing happened to me just now...lol! my '01 won't start...radio comes on, batt reads bout 9v. ****load of rubber/gel like corrosion on my neg post. got most of it off with a screwdriver...just ran up here now for a wrench. still won't start...all i get is one click when i turn the key.
DSMtuner is offline
post #6 of 6 Old 07-31-2006, 05:42 AM
Jaws2381
I think it's your battery. I have a 2001 I6 as well and this happened to me two weeks ago. Every thing was fine and then in a parking lot I tried to start it. It didn't turn over immediatly so I stoped. Then Clicking sounds in the dash and door. You battery can have enough power to keep your lights on yet not enough to even try to start. Make sure their is no corosion on your terminals and your connection is solid... I replaced my battery and clean up my terminals and it starts up like a champ now.
Jaws2381 is offline
4.0 starting problem jeremy8302 ZJ Grand Cherokee Forum 5 07-11-2009 03:34 PM
Starting problem klockdoc ZJ Grand Cherokee Forum 3 06-12-2009 07:35 PM
5.2L Starting Problem WickedZJ ZJ Grand Cherokee Forum 8 05-21-2009 09:19 PM
96 4.0L GC starting problem cromero ZJ Grand Cherokee Forum 1 07-28-2007 07:16 AM
Starting problem inkmonki ZJ Grand Cherokee Forum 3 05-25-2006 03:58 PM
