Quantcast Starting problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Starting problem
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 05-22-2006, 02:37 PM   #1
inkmonki
Starting problem
my wife's ZJ has a problem starting after it has been running. It always starts and runs great but after i turn it off and try to restartit it doesnt crank, or make any noise whatsoever. All the indicator lights and instrument panel gauges light up and read properly, i can operate power windows too, but it won't turn at all. This has me stumped if you guys have any suggestion i would much appreciate it. It is a 97 4wd 6 cyl grand ZJ, a/c, and auto tranny.
Can the starter just go bad like that from overheating? i have checked loose wires as well from the starter and alternator. totally stumped.
[SIZE=2][COLOR=DarkOrange]95 xj was jacked and stripped by 2 homies.[/COLOR][/SIZE]
[COLOR=Red][SIZE=2]now i roll in a black 2000 WJ, pics of mods
coming soon.[/SIZE][/COLOR]
inkmonki is offline   Reply With Quote
Old 05-25-2006, 04:23 PM   #2
inkmonki
here's some fyi....it was my starter. i suppose the solenoid is goin bad on it. i found out using the old hit it a few times with the wrench trick.
Old 05-25-2006, 04:29 PM   #3
Varkyl
No where near stock
Varkyl's Avatar
The solenoid getting hot will cause the issue that you had. My '70 Chevelle was real bad about that. I seemed like every summer I would have to put in a new starter because of that.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline   Reply With Quote
Old 05-25-2006, 04:58 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
They are very easy to replace. I believe there are three bolts and one electrical connector.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Glock Forum
