starting problem - JeepForum.com
post #1 of 6 Old 12-21-2002, 05:38 PM Thread Starter
sullyce
starting problem
My 93 Grand Cherokee won't start on the first crank - I have to turn the key off and on 5 to 20 times until the check engine light comes on before it starts. On the control panel the oil level light is on despite no need for oil. This sensor was replaced along with a tune up- and within a few days the oil light was on again and running rough. Any suggestions would be greatly appreciated....P.S. - now I'm having trouble with my headlights..they wouldn't go on low, only high until I shut my jeep off and on a few times, then they worked....something in my wiring?
sullyce is offline
post #2 of 6 Old 12-21-2002, 11:40 PM
MJR
MJR's Avatar
1988
What does it do ?. When you turn it to the crank position does it make a single click noise ?.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 6 Old 12-22-2002, 09:52 AM Thread Starter
sullyce
starting problem
No clicking noise - it cranks like normal, but doesn't start until the engine light comes on
sullyce is offline
post #4 of 6 Old 12-25-2002, 04:39 PM
MJR
MJR's Avatar
1988
Sounds unusual. Two of the most common things that can cause a cranks no start problem are the fuel pump and ignition coil.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #5 of 6 Old 12-25-2002, 07:06 PM Thread Starter
sullyce
starting problem
The mechanic checked the fuel pump- that was ok. I'm coming to think the problem is in the wiring harness where it comes thru the firewall in the breaker box driver's side. I had problems a while ago with wiper delay ....as well as the factory alarm - I have been unable to lock the jeep for fear of that annoying honking...
sullyce is offline
post #6 of 6 Old 12-25-2002, 09:41 PM
MJR
MJR's Avatar
1988
The primary problem with the alarm system on 93-95 was the underhood switch. This was eliminated in later years for this reason. I always just pull it out and throw it away. The problem was that as the hood expanded/contracted from temperature changes it would trigger the alarm. It's over by the battery.
The alarm can be reset with a key in the LF/RF/Hatch or with the keyless remote.
I have seen water leaks on the driverside cause problems also.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
WJ starting problem ktplotts ZJ Grand Cherokee Forum 12 08-03-2006 03:47 PM
Starting Problem Chuck831 ZJ Grand Cherokee Forum 5 07-31-2006 05:42 AM
Starting problem inkmonki ZJ Grand Cherokee Forum 3 05-25-2006 03:58 PM
Starting problem -Joe- ZJ Grand Cherokee Forum 42 11-15-2005 07:43 PM
Starting problem miataeric ZJ Grand Cherokee Forum 3 08-22-2004 01:34 PM
