Quantcast Starting problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Starting problem
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 08-21-2004, 04:24 PM   #1
miataeric
Starting problem
My jeep never starts on the first try. I used to crank it two or three times to get it going. Now I just turn the key to the "on" position and wait for the pump to run. I do that two or three times before I crank it. When I do that, it starts right away.
I'm hoping the problem is not in the pump module since I don't want to remove my gas tank or cut a hole in my floor. If it is the pump, I'll just do the Swampy Bypass while I have it all apart. Why did they put the pump in the tank in the first place?
Stock 1998 ZJ 4.0 w/ Select-Trac
miataeric is offline   Reply With Quote
Old 08-22-2004, 08:54 AM   #2
miataeric
Could there be a leak between the pump and the injectors causing pressure to drop off once the car sits (turned off) for a while? If you turn it off and back on again quickly, it starts right up.
Old 08-22-2004, 02:20 PM   #3
miataeric
Numbers
I've got more information now. I tested the fuel pressure and these are my results:
If I turn on the pump (put key in ON position): 15psi, dropping very quickly to 0.
If I turn the pump on twice (On - Off - ON): 30psi, dropping very quickly to 0.
If the car is idling, 50psi which is within the normal operating range.
Any ideas?
Old 08-22-2004, 02:34 PM   #4
driabyor
1994 ZJ
there is a one way valve but location unknown most likely on pump.... and probably not serviceable... i guess you can add one inline by the filter.....
or just wait a few seconds before you try to start it each time....
you know turn key on then fasten your seat belt then start the jeep
driabyor is offline   Reply With Quote
Glock Forum
