Starting my BDS 6.5" Long Arm lift - JeepForum.com
post #1 of 46 Old 09-17-2013, 10:52 AM Thread Starter
-Otter-
I'm currently on my second ZJ. My first one was thoughtfully named the "Green Menace" due to having it straight piped. That one crapped out on me so I bought another. This one is different than the first by having the 5.2L, a NP249, and a Dana 44HD rear end.
I bought it bone stock and immediately put 3.5" RE lift on it. Then I bought a set of 31"x10.5" General Grabber Red Letters. So far I have trimmed the front bumper, cleaned up the axles front and rear and re-painted them, changed all my fluids, added a CB antenna mount off the drivers side tail light, made a custom external speaker mount with picnic tablecloth holders, an last but certainly not least joined my local jeep club.
I've driven it for about 5000 miles and I am already set to change the jeep again. Here's my plans:
NP242 t-case swap:
23 spline input shaft
0.840" diameter input shaft
Newish front driveshaft
Newish rear driveshaft
242 shift linkage
242 shift indicator sensor
242 bezel
242 rear output seal-4370N
242 front output seal-3946
242 dual lip input seal-710928
46RE output seal-710058
242 master rebuild kit-52270.1007 (crown #242lmaskit)
2qts ATF
2qts ATF+4
Front axle e-locker with 4.56 Yukon gears:
C-clip
27 spline
7.12"ring gear
Spicer joint shaft swap
Chromoly shafts
New wheel hubs
Rear axle lunchbox locker with 4.55 Yukon gears:
C-clip
30 spline
8.5" ring gear
Chromoly shafts
New wheel hubs
New u joints
And finally BDS 6.5" Long Arm with 35"x12.5" Red Letters.
Please feel free to chime in and offer any advice. I'm looking to start purchasing parts here in a couple weeks so I still have time to makes changes for the better.
Chris (Otter)
1996 Grand Cherokee, 5.2L, 46RE, NP249
3.5" RE coil lift, 31x10.5x15 General Grabber Red Letters
Cobra Cb with 4' Barjan antenna
-Otter- is offline
post #2 of 46 Old 09-17-2013, 05:06 PM
hotrodjeeper
I have BDS 6.5" springs in my 5.9 and they sagged 2 inches and I had to put 2.25" BB
up front to level with the rear. Just a heads up if they sag on you.
BUILD THREAD BELOW http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/"]http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/
hotrodjeeper is offline
post #3 of 46 Old 09-17-2013, 05:43 PM
riot1987
You like those Generals? I was going to get some but heard they are a pretty soft tire. Great offroad but heard they tend to wear kind of quick.. True?
Build thread^^
riot1987 is offline
post #4 of 46 Old 09-17-2013, 06:57 PM Thread Starter
-Otter-
Well I have the 3" spacers I'm running right now I can throw in if need be. I'm assuming the BDS kit keeps the factory rake, so the spacers would level it if they sag. Correct?
-Otter- is offline
post #5 of 46 Old 09-17-2013, 06:58 PM Thread Starter
-Otter-
I've only put about 500 miles in mine. But I got mine at the recommendation of a buddy in my jeep club. He's on his second set and he got 50,000 out of his first ones on his DD.
-Otter- is offline
post #6 of 46 Old 09-18-2013, 11:25 AM
JohnnyZJ
claytons long arm kit. you're already spending good money might as well get the best on the market. plus the rear comes with a bridge/truss for the diff. if you are running a 44a might you should truss it anyway. two birds, one stone.
also your front diff isn't a 'c clip' axle. rear is. won't matter with your plan. just an fyi.
go get'r done. sounds like Visa/Mastercard/AMEX are going to like you alot........
07' JKUR rollin on 35s
JohnnyZJ is offline
post #7 of 46 Old 09-18-2013, 11:41 AM Thread Starter
-Otter-
I thought the 30 was a c-clip? Since it isn't that means the shaft seal and bearing are press fit right?
And I thought about doing the Clayton's. It is a very nice kit. However I am buying parts of the kit they payroll deductions thru the dealership I work for. And the Offroad company they work with is a BDS retailer so I get a smoking discount. The guy I'm ordering from is in the jeep club with me and doing some math we figured I'm getting about a grand off the lift itself.
-Otter- is offline
post #8 of 46 Old 09-18-2013, 12:42 PM
JohnnyZJ
if you get a deal then thats cool. can't argue that.
the D30 is a full floater so no C clips. teh bearings, are the unit bearings on the knuckle which carry the load. there are no bearings pressed on the shaft.
the rear is a semi float and works as you described. and your only locker option on that is indeed the drop in. they are fairly easy to install, but getting the C clips to line up is a *****. lol.
good luck with it!
JohnnyZJ is offline
post #9 of 46 Old 09-18-2013, 12:59 PM Thread Starter
-Otter-
good luck with it!
Yes working it through my dealership is bringing the price from about $3500 to $2400.
Thanks for the info!
-Otter- is offline
post #10 of 46 Old 03-28-2014, 05:54 PM Thread Starter
-Otter-
Been a while since I posted on here. Put on the Kevins Offroad Radiator Supports Tow Points. It was a very straight forward install. Love having the tow points there. Also picked up a K&N Intake at the JY for $15.
-Otter- is offline
post #11 of 46 Old 03-29-2014, 05:00 AM
Technohead
If you are building a wheeling rig the forget about the 242 and get a 231. More ground clearance, more aftermarket, simpler, stronger . . .
-Eric
Technohead is offline
post #12 of 46 Old 03-29-2014, 05:15 AM
speedbucket
He beat me to it....lol^
231 instead for sure
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #13 of 46 Old 03-30-2014, 08:47 AM Thread Starter
-Otter-
A 231 is the one that has 2 low correct?
-Otter- is offline
post #14 of 46 Old 03-30-2014, 09:27 AM
riot1987
Im not arguing that a 231 is the "ideal" case for your rig HOWEVER, I have had my 242 in 2 jeeps one of which was dumped in a pond and left overnight. All Ive ever done with that 242 is change fluid. NO issues whatsoever.
Build thread^^
riot1987 is offline
post #15 of 46 Old 03-30-2014, 10:15 AM
PolkaPower
2lo ? lol.
PolkaPower is online now
