Starting Issues/No Oil Pressure (Seafoam) - JeepForum.com
post #1 of 8 Old 07-18-2013, 01:46 AM Thread Starter
zRoxxah
Alright so as most of you know from my 3 other threads, I seafoamed the ZJ. [Sorry about the flooding, I'm getting desperate] All went well except she stalled prematurely (to fast down the brake booster) and she died on the "victory drive." I didn't have oil pressure so I did a roadside oil change which didn't help anything. SO I changed my spark plugs which is adviced if your having post-seafoam issues. I just got done with that and she started up real nice and strong. And then my lamp hanging from the hood fell, shattered and upon impact the engine died LOL. I'm pretty sure that was pure coincidence since a lamp falling on the valve cover/alternator shouldn't do anything.
I tried to start her up again and she didn't turn over after the first few cranks so here I am. I still don't have oil pressure. And I cleared all the glass shards...lol
Seriously...what is going on here?
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline
post #2 of 8 Old 07-18-2013, 01:54 AM Thread Starter
zRoxxah
I also found this when changing my oil filter. I'm sure what it is but it looks broken. It sits right above the oil filter on the oil filter adapter.
zRoxxah is offline
post #3 of 8 Old 07-18-2013, 06:50 AM
96zedjay
Thats your oil pressure sending unit. Explains the no oil pressure thing.
96zedjay is offline
post #4 of 8 Old 07-18-2013, 11:44 AM Thread Starter
zRoxxah
Alright so I replaced the oil sending unit. Still no pressure. I should've know this since before I left the driveway to go on the victory lap I didn't have pressure. I'm going to drop the pan and clean the pick up line then see what happens.
Basically she starts sometimes, no oil pressure on the gauge and stalls about after 3-5 minutes. Fresh spark plugs and a full tank.
zRoxxah is offline
post #5 of 8 Old 08-02-2013, 06:05 PM
djtricia
No oil pressure/stalls
Could it be that the fuel pump shuts off if there's no oil pressure?
djtricia is offline
post #6 of 8 Old 08-03-2013, 12:25 AM
eagsc7
1994 ZJ
Nope. my sender was broken for a few months, and never had any issues. Check your spark plug wires to make sure they're in the right place(order). Also, Have you changed your Crankcase Position Sensor? If not, then change it out...
eagsc7 is offline
post #7 of 8 Old 08-03-2013, 12:36 PM
Muskitokid
1994 ZJ
I know you said new plugs, but are you getting good fire to them from the coil?
Muskitokid is offline
post #8 of 8 Old 08-03-2013, 01:23 PM
Oldfrog
2007 WK
Stalls after 3-5 minutes? Like when the temp gauge starts getting near the 210 mark?
If so, unplug your upstream o2 sensor. It will give you a check engine light...but see if it stalls with it unplugged. If not....replace it with an NTK brand sensor. Rockauto.com has them for about $32.
Otherwise, go thru Zeejays dirty dozen list.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
