Hello, I just joined the jeep community yesterday. I bought a 1997 Grand Cherokee Limited with the 6 cylinder! This site has a wealth of knowledge, thanks everyone. When I bought the car it fired up without a hitch. When I tried to start it up this morning all I got was cranking and no running. If someone could throw some insight my way I would be very thankful. Im no mechanic but I think it is a fuel problem...?
If you wanna check fuel system:
Do you hear the fuel pump when you turn the key to "on"?
If so get a fuel pressure gauge and check fuel pressure before a cold start and after warmed up. Start with that and post your findings.
When you check pressure cold, do so "before" you crank engine over. You wanna see if your leaking fuel pressure over a period of time (injector, check valve, or system leak)
its probably fuel but to rule out the CKS just pop off the wire that runs from the coil to the distributor, have someone try to start it while you hold the wire close to the block or valve cover, it should arc over rapidly. if you have a multimeter you can also test for voltage at the coil harness
Thanks for the advice guys, it turned out to be a bad connection at the pcm. I replaced the wiring harness and pcm. I was able to find a rebuilt one for $200 dealership wanted $800! Once the new one was in it threw out the code for the IAC. Replaced that and Im good to go.
On another note, I noticed a rattling sound coming from the front end when Im idling in first gear. It doesn't always make this noise, but when it does it is pretty noticable. Sounds like something is shaking against something else possibly.
check the exhaust shielding on the cat. also tap it with a screwdriver and see if it rattles, they often cause rattling at idle when they die and the shielding typically breaks free of them and can cause it as well
Thanks heep, I read about the cat in another threadd and im going to check that ut on my nect day off. I cant thank you ennough, this had been the most helpful forumi have ever participated in.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
