Starting a 99 WJ build.... Im a noob all the way need help! - JeepForum.com
post #1 of 13 Old 04-23-2009, 08:52 PM Thread Starter
Goodpaster
First off I got a stock 99 WJ Limited 4.7 Quad-Trac II
I got this jeep back in 99 has 130000 miles... The boots came off the cv joints in the front and went to hell... So now Im going to need new axles ...
If Im going to do this might as well upgrade and lift it.... Other than the cv joints going bad the jeep is top notch... I got bout $2000 to spend on the lift,axles,tires for stock rims and whatever I need for it all to work well...
Would like to go as big as I can.... Where do I start?
Sorry guys but Im a noob to this and have no Idea
Here is a pic of the jeep now
Goodpaster is offline
post #2 of 13 Old 04-23-2009, 09:01 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Why can't you replace the axle shafts instead of getting entirely new axles? Cause if 2K is your budget, axles will eat that up really quick.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 13 Old 04-23-2009, 09:06 PM Thread Starter
Goodpaster
If stick with stock I can get them for $80 from my brother-n-law... If that would be the best thing for me to do... I could drop up to $3000 but I think if I shoot for $2000.... Ill end up around $3Gs... I just want to do it right with the money I have to spend and not look back and say wish I would have done this....
post #4 of 13 Old 04-23-2009, 09:11 PM
GraKee99
Rapist Wit
GraKee99's Avatar
How big of tires are you looking to run and is this going to wheeled or will it be just a mall crawler?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 13 Old 04-23-2009, 09:19 PM Thread Starter
Goodpaster
Were I live in Kentucky we have no mall... Im not wanting to lift it so it will look cool when I go to town.... It will be wheeled but still need it as a DD... Would like to get at least 33 under her if I can.... Im not going to be jumping her off rocks but need it for more off road
post #6 of 13 Old 04-23-2009, 09:25 PM Thread Starter
Goodpaster
BTW..... I am reading up on alot here just found the site... I know some of you will look over my post as Im sure people has asked this 1000 times.. but Im kinda in a rush because its my DD and now Im stuck bumming rides....
post #7 of 13 Old 04-23-2009, 09:26 PM
GraKee99
Rapist Wit
GraKee99's Avatar
With 2K, it will be hard to get a big enough lift to run 33s. If you wanted to commit 3K it would be a little less challenging but still would be close. You could do 32s and be around 2K with tires.
A problem that could arise is that you more than likely have a cv jointed drive shaft which will need to be swapped to a u-joint if you get a lift over 2.5". Do you know what style your front drive shaft it?
Honestly, if you limit is 3K and you want to lift it just replace the axles shafts. The Dana30 and Dana44a will hold up with 33s as long as you go easy with the skinny peddle offroad.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #8 of 13 Old 04-23-2009, 09:32 PM
Jones
Consider the following...
Jones's Avatar
I've been at 4.5" and stock CV for the last year. Who makes axle shafts for the 44a? I would be interested in that. Oh yeah, I've also had 33's with stock axles for the last year too. But to be safe upgrading them wouldn't be a bad idea.
I would go with something like this, http://www.ironrockoffroad.com/Merch..._Code=IR-W4CPK with 32's, or 33's if you don't mind trimming.
Jones is offline
post #9 of 13 Old 04-23-2009, 09:52 PM Thread Starter
Goodpaster
I dont mind trimming... I really like that kit.... What should I do bout this axle problem? Stay with stock or what?
post #10 of 13 Old 04-23-2009, 09:54 PM
Jones
Jones's Avatar
In my experience I haven't had any problems with a D30 front, D44a rear, and 33's. My axles are completely stock. Others may have had issues though.
Jones is offline
post #11 of 13 Old 04-23-2009, 09:56 PM
spife7980
i would. maybe put in some chromolies if you have the cash but if not i would just go down to napa and get some lifetime warranty ones.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #12 of 13 Old 04-23-2009, 10:00 PM
99avant
For 2k? hmmm
Iro 3" (http://www.ironrockoffroad.com/Merch...egory_Code=PFW)
Some 32" bighorns
Tow Hooks, rear hitch if you dont have one, sliders
All that plus an alignment should land you around 2K. That would make a pretty capable Wj
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #13 of 13 Old 04-23-2009, 11:08 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by 99avant View Post
For 2k? hmmm
Some 32" bighorns
That was my thoughts exactly.
Brian
WJ, WK, CJ5
GraKee99 is offline
Grand cherokee noob 46RH starting gear problems kain000 ZJ Grand Cherokee Forum 5 07-27-2009 02:46 PM
I might be starting a GC build JFranko ZJ Grand Cherokee Forum 5 02-16-2009 10:14 AM
Build sheet Q from a noob billzcat1 ZJ Grand Cherokee Forum 12 11-18-2008 08:10 AM
Noob saying Hello!! XxWickedz28xX ZJ Grand Cherokee Forum 18 02-19-2007 09:35 PM
No starting/hard starting in cold KrazysJeep ZJ Grand Cherokee Forum 3 10-23-2006 06:14 PM
