Starter Write-up/How-to - JeepForum.com
post #1 of 3 Old 02-07-2014, 10:59 PM Thread Starter
bigray122
1993 XJ Cherokee
Forgive me if I've missed it or searched and didn't find it. But I'm looking to replace my started and write-ups always help the process along. Is there one on this site or any other?
Here is my issue. Brand new batter in November. Then about a month ago, I went to start it and it sounded as if the battery were dead. I hit it with the charger. That happened a few times. Then that wouldn't help either. So I grabbed pliers and tapped away at the starter in desparation. BOOSH! Worked like a champ. I've been doing that for a week now. It sounds like a starter issue to me.
Any help would be appreciated. Thanks in advance...
Ray
bigray122 is offline
post #2 of 3 Old 02-08-2014, 09:35 PM
shaban
Doing starter's real easy, just 2 bolts to take out (on different sides of bellhousing though). Take the electric loom off first (small socket & ratchet helps here)
Dont forget to disconnect the battery since starter is energised even with ignition off.
shaban is offline
post #3 of 3 Old 02-08-2014, 10:03 PM
Uniblurb
Uniblurb's Avatar
Yeah, my son used to carry a hammer with him to tap the starter when the armature ended up on a dead spot. Pretty simple to replace as shaban said, disconnect the battery first, and here's a real short video. Use some brake cleaner with wire brush/emery cloth or sandpaper to clean the old oily contacts off before connecting a new one and good idea to wear safety glasses.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
starter , starter issue
