Starter Spins Out ? - JeepForum.com
post #1 of 8 Old 05-30-2007, 01:50 PM Thread Starter
Briandl
Starter Spins Out ?
I was looking at my FSM and it says:
Condition: Starter Engages, Spins Out Before Engine Starts
Causes are the ring gear or the starter itself.
If I have no spark, should the starter spin out, or do I have a problem with my starter?
I've done some troubleshooting and I definitely don't have spark, I get voltage to the ignition coils but I don't get a pulse, or a ground.
Briandl is offline
post #2 of 8 Old 05-30-2007, 02:36 PM
UUJ1
If your starter isn't turning your motor over... you're not going to get spark. Replace your starter.
UUJ1 is offline
post #3 of 8 Old 05-30-2007, 02:41 PM Thread Starter
Briandl
It turns the motor over for a second or so and then spins out, no spark after some testing with a voltmeter and a test light...
Briandl is offline
post #4 of 8 Old 05-30-2007, 02:42 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You have been here long enough to know that you should have your Jeep info in your sig or profile
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 8 Old 05-30-2007, 02:48 PM Thread Starter
Briandl
Yup........
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #6 of 8 Old 05-30-2007, 03:29 PM
UUJ1
YOu still need a new starter...
UUJ1 is offline
post #7 of 8 Old 05-30-2007, 06:59 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Starters are easy to replace.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 8 Old 05-30-2007, 08:42 PM
Test
2007 WK
Bendix is bad. Replace the starter.
Test is offline
Starter ! inlinegrand6 ZJ Grand Cherokee Forum 3 06-19-2008 07:23 PM
Starter went @ 20K on an 07??? 07JGCX WK Grand Cherokee & XK Commander Forum 2 06-19-2008 01:13 AM
oil cap just spins in place subzero32 ZJ Grand Cherokee Forum 9 03-22-2008 05:34 PM
help with starter!!!! WJ 00grand ZJ Grand Cherokee Forum 9 11-29-2007 10:52 AM
Starter... right? BlackPearl96 ZJ Grand Cherokee Forum 12 11-28-2007 12:03 PM
