Starter Motor issue - JeepForum.com
post #1 of 6 Old 10-23-2013, 12:55 PM Thread Starter
johnpartington6
Starter Motor issue
I replaced the original starter motor on my Grand Cherokee 2.5 diesel with a non 'jeep' replacement but it always made a strange whirring sound when starting and the motor only lasted a few months, assuming a bad motor I replaced again with non jeep and the same happened. Has anyone had this problem or can anyone confirm that 'jeep' starter motor only is suitable and why?
johnpartington6 is offline
post #2 of 6 Old 10-23-2013, 01:37 PM
WJ4x4LIFE
Aftermarket parts are aftermarket which in turn are not exactly OEM, granted. However you will sometimes more than not get a fairly decent part from your local parts store. I have to say that unless, the retail aftermarket starter's gear was not aligned properly or gear housing damaged, issues can arise. To answer your question. However, I have to say, the same issue has arisen before in a Jeep Liberty 2.5L LTD, closes thing I have over here. When this happened to me at work, I just ordered a factory starter and ate the difference to help the customer out. Rather this is helpful or not, I gave it a shot. Unfortunately, I do not have anymore information, but will research some more and get back.
WJ4x4LIFE is offline
post #3 of 6 Old 10-24-2013, 11:59 AM Thread Starter
johnpartington6
The aftermarket parts seemed to fit ok and flywheel seems ok as no metal shavings apparent when we removed them. The noise sounds like the starter is not disengaging quickly enough or something so maybe the OEM version is very slightly diferrent? I will try a cheap used OEM starter just to test the theory first without too much cost and will post here how I get on. Thanks.
post #4 of 6 Old 11-06-2013, 12:53 AM Thread Starter
johnpartington6
I have obtained a starter motor but it is made by 'bosch' is this an original jeep part ot aftermarket, if so who should the manufacturer be?
post #5 of 6 Old 11-06-2013, 03:55 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I could be wrong but I think it was denso or mitsubushi. Don't quote me on that one.
Originally Posted by HighLonesome
coralman is offline
post #6 of 6 Old 11-12-2013, 12:37 PM Thread Starter
johnpartington6
Can anyone confirm if the starter motor should have 9 or 11 teeth? The car is 2.5 diesel and was manufactured 1998/1999.
