Starter Clank - JeepForum.com
post #1 of 19 Old 09-20-2011, 03:17 PM Thread Starter
ZJ5point2GCL
Starter Clank
Heres a video of it starting, you can here right after it starts the clank of the starter. Its like the starter doesn't pull away fast enough and catches the fly wheel. Ive tried the starter from my 5.2, and a new one from napa, all 3 do the same thing, ive tried washers to pull it further away. Ive taken the inspection cover off the trans and looked at every single tooth on the fly wheel, i ve watched the fly wheel while its running and it has no run out or odd vibrations.
I am at a loss, please help.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #2 of 19 Old 09-20-2011, 09:22 PM Thread Starter
ZJ5point2GCL
anyone?
post #3 of 19 Old 09-21-2011, 03:37 PM Thread Starter
ZJ5point2GCL
Bump
post #4 of 19 Old 09-21-2011, 08:59 PM Thread Starter
ZJ5point2GCL
Really? no one has any wisdom to enlighten me with?
i am getting a little bored driving my twin turbo minivan every where.
please, any ideas, any at all.
might just pull the trans off and replace the fly wheel, but i really really really dont want to.
post #5 of 19 Old 09-21-2011, 09:24 PM
phitmein
phitmein's Avatar
You know I would gladly help you if I could.
I would say look at the flex plate but I bet you have already.
How long is that video ? I have dial-up and it can take forever.
Have you tried doing it with the coil wire off to see what it does not running ?
phitmein is offline
post #6 of 19 Old 09-21-2011, 10:10 PM Thread Starter
ZJ5point2GCL
the video is 14 seconds long. (both are, but second one you can hear it a little better)
i have taken the coil off, and it doesn't make any unusual noises, it just seems to do it when the motor revs up a bit when it finally and it would still be slightly engaged.
yes i have looked at the flex plate, i spent 30 minutes under there with a flashlight and a wrench on the crank looking at every single tooth, i started it with the inspection cover off, and looked at it running, the flex plate doesn't have any run out, nor does it wobble or anything.
i don't think you need to shim these starters like old chevs but i could be wrong, its near impossible to check clearance anyways.
post #7 of 19 Old 09-21-2011, 10:38 PM
JS97ZJ
Starter relay staying energize when key is released?
JS97ZJ is offline
post #8 of 19 Old 09-21-2011, 10:40 PM
phitmein
phitmein's Avatar
I finally got the 1st vid downloaded and at about 10 seconds I see and hear the compressor clicking on ?
I knew that you would have checked the plate but threw it out there anyway.
Have you done anything new to it or has this just started out of the blue?
I will download the 2nd vid and see what I hear now.
phitmein is offline
post #9 of 19 Old 09-21-2011, 11:01 PM Thread Starter
ZJ5point2GCL
i don't think so, i did put a test light on it, and seems fine, did swap relays, no different.
i also tried holding the key longer than i should, and it only seems to do it right after i let go, like when the starter is sucking back.
post #10 of 19 Old 09-21-2011, 11:13 PM Thread Starter
ZJ5point2GCL
its right after it starts, may have to turn the volume up a bit.
it started doing it after i fuel hydro locked in moab and the mechanic there tried turning it over, i had initially thought i sheared some teeth from the flex plate and it just made noise as it passed over.
then i checked out the flex plate an it was all normal, so i figure possible it bent the shaft on the starter and it wasn't releasing quick enough, so i stole the starter off my 5.2, watched how fast the gear sucked back on both of them and the 5.2 one ( pretty new) did suck back faster, so i thought great it must be that, put it in and it was worse, so then i called a friend and we looked over everything agin and everything mechanical checked out, so i figured i had nothing to loose by buying another starter (other than 200 bucks , but o well) then it did the same thing.
i am not sure if its possible that it bent the bell housing where it mounted at all, tomorrow i might try open up the holes on the starter a bit so i can position it a little further away from the flex plate.
i mean if i have to pull the trans at that point i might as well stick a 408 under the hood.
i also only have very limited time to work on it, going to school and working full time, ive been working on it when i come home at 3 in the morning for a few hours before i have to wake up at 7 for school, and running to napa on lunch breaks. so needles to say its a huge frustration
post #11 of 19 Old 09-21-2011, 11:23 PM
phitmein
phitmein's Avatar
All work and no play makes Jack a dull and very burnt out boy.
Sorry Jake I can't hear it in the second vid either.
I will listen to it somemore but I do have the volume up all the way.
Your motor does sound sweet by the way.
phitmein is offline
post #12 of 19 Old 09-21-2011, 11:35 PM Thread Starter
ZJ5point2GCL
I know, its brutal.
its like maybe 5 seconds in, that clatter right after it cranks.
haha thanks, after driving my truck for too long i start to think it sounds good, then i fire up the jeep and remember how good v8's sound, diesels, v10's and turbo v6s just don't have them same beautiful sound.
post #13 of 19 Old 09-21-2011, 11:37 PM
swillett
what do the teeth on your starter pinion look like?
swillett is offline
post #14 of 19 Old 09-21-2011, 11:39 PM Thread Starter
ZJ5point2GCL
good almost no wear on the original starter, and the one from napa has a brand new gear.
if i can find some, i could put some gear marking compound on it, to make sure it doesn't have some strange contact pattern.
post #15 of 19 Old 11-30-2011, 09:47 PM
phitmein
phitmein's Avatar
Jake did you ever figure out the starter problem ???
phitmein is offline
would a bad cv joint howl or clank at about 30 mph? ronsaun ZJ Grand Cherokee Forum 0 11-08-2009 12:11 AM
bad cv howl or clank? ronsaun ZJ Grand Cherokee Forum 0 11-06-2009 11:32 PM
2004 4.7L HO engine clank noise? SD Willy ZJ Grand Cherokee Forum 3 04-03-2009 11:07 PM
clank noise from center stack sabre364 WK Grand Cherokee & XK Commander Forum 5 12-14-2008 03:22 PM
rear brakes clank jnblkjp ZJ Grand Cherokee Forum 0 08-07-2008 02:45 PM
