start then no start? - JeepForum.com
post #1 of 12 Old 08-24-2011, 04:42 PM Thread Starter
metallica0682
ok so I sanded and painted my rims,did nothing else..go to move her to the front of the house and it won't start. I wacked the starter nothing, then I rocked it back and forth by the tire tried it and she started up drove it to the front of the house shut it off tried to start again and nothing! battery is new,starter 1yr old, altinator 1yr old, ingnition swith 1yr old, had simular problem a year ago turned out to be the ingnition swith. And thats why all electric parts are new...any ideas?
metallica0682 is offline
post #2 of 12 Old 08-24-2011, 05:49 PM
phitmein
phitmein's Avatar
not even a click ???
clean the connections ...
tap on the starter with a hammer ...
phitmein is offline
post #3 of 12 Old 08-24-2011, 05:58 PM
iGotTheRunz
I had a similar problem. The shift cable needed to be adjusted. For whatever reason it wasn't fully in park. After the adjustment it hasn't happened again. Just an idea.
iGotTheRunz is offline
post #4 of 12 Old 08-24-2011, 06:03 PM
savannahzj
nss
savannahzj is offline
post #5 of 12 Old 08-24-2011, 06:04 PM
phitmein
phitmein's Avatar
My bad, I see that you have already whacked it ...
May try jumping the solinoid ???
phitmein is offline
post #6 of 12 Old 08-24-2011, 06:09 PM
phitmein
phitmein's Avatar
Savannahs probably right, try moving the shifter around some and try it in netrual too ...
phitmein is offline
post #7 of 12 Old 08-24-2011, 08:18 PM
iGotTheRunz
Originally Posted by savannahzj
nss
nss?????
post #8 of 12 Old 08-24-2011, 08:27 PM
savannahzj
non searching sob's... just kidding. neutral safety switch
post #9 of 12 Old 08-25-2011, 12:03 PM Thread Starter
metallica0682
ok so attacked it again this morning beat the hell out of the starter and bamm she runs again! So I think it's time to replace the starter..again even tho it's only a yr old. thanks for all your help guys...again with out this site I would be LOST.....
post #10 of 12 Old 08-25-2011, 12:25 PM
melk
I'd keep looking for whatever underlying problem is killing your starter before it fries this next one too. How's the ground strap and connections look?
Also, I know of the trick to bang on the starter, but are you supposed to hit the end of the cylinder? Or the side? Or just bang the hell out of everything?
melk is offline
post #11 of 12 Old 08-25-2011, 01:31 PM
phitmein
phitmein's Avatar
I have always hit the sides ...
phitmein is offline
post #12 of 12 Old 08-25-2011, 04:56 PM
iGotTheRunz
Nice! Acronym using #@%$%&$@!
No start/hard start in/after heavy rain. BenzB ZJ Grand Cherokee Forum 1 03-08-2011 06:11 PM
Hard Start---> No Start. Fuel pump? please help Eddmcm228 ZJ Grand Cherokee Forum 5 02-13-2011 10:44 AM
Rough start, sounds like a diesel after start up until warm.. SteelBlue_WJ ZJ Grand Cherokee Forum 7 10-05-2009 07:39 PM
bypassing the factory Start mechanism (push button Start) Jey109 ZJ Grand Cherokee Forum 16 08-30-2009 06:24 PM
Hot Start Problem.... Cold Start Injector??? Mase ZJ Grand Cherokee Forum 3 02-03-2003 09:33 PM
