The start of the repairs - axle swap - help! - Page 2 - JeepForum.com
post #16 of 21 Old 08-26-2013, 11:09 AM
OverlandZJ
Espescially since 3:73 4.0L ZJ's are somewhat uncommon. Piece of mind mate..
OverlandZJ is offline
post #17 of 21 Old 08-26-2013, 12:43 PM Thread Starter
Rockingdad
ok so just had a look, firstly a shout out to the IDIOT who put the id tag on the diff face in so you cant see you info!
Anyway details as follows:
52098940
* 73 610574
I've put a star as I levered off the tag at one end to read the info underneath (as wrong way round) and the first digit was not readable, i'm guessing it's a 3 though as the rear tag was.
Cheers
RockingDad
Rockingdad is offline
post #18 of 21 Old 08-26-2013, 01:55 PM
OverlandZJ
Grab that low mileage 3:73 axle then.. your golden.
Might be a good move to grab the front also as a spare considering the low mileage.
post #19 of 21 Old 08-27-2013, 10:46 AM Thread Starter
Rockingdad
Ok so update after getting back from the breaker yard,
Donor Jeep axle tag has:
53055072 LS
3 73 5805-4
So am I happily right in saying it's a direct swap for mine without issue?
My current axle:
52098941 LS
3 73 5806-4
Is there anything else I need to consider regarding the axle or just stop worrying/mucking about, praise my good luck at a ratio match and swap em?
Cheers
Rockingdad
post #20 of 21 Old 08-28-2013, 03:21 PM Thread Starter
Rockingdad
Is somebody able to confirm for me?
Cheers
Rockingdad
post #21 of 21 Old 08-28-2013, 04:14 PM
kg6mov
Hears the voices
kg6mov's Avatar
Looks good, I believe the LS is limited slip, should be good.
Pop the cover anyway and check it before installing. New fluid with friction modifier for the lsd
kg6mov is offline
