Start problems 96 ZJ - JeepForum.com
post #1 of 7 Old 08-17-2013, 05:19 PM Thread Starter
BBZJ
First, I've read these both, even printed it out.
http://www.jeepforum.com/forum/f13/1...talls-1407423/
http://www.jeepforum.com/forum/f13/f...l#post15720747
I'm about a quarter of the way through the 12 things, really not sure which one to go to next.
Jeep wont start, cranks but never turns over. Go to bottom for TLDR.
History: Jeep has never had start issues. This winter I was getting ready to put it in the garage when i started it and let it run to melt the frost off. I scraped off the other cars in the driveway to get ready for the three car shuffle. Before long i realized the jeep was not running anymore. It wouldnt start after that, hasnt started since. Cranks fine just wont turn over.
Replaced So Far: Distributor cap, button, plugs, plug wires, battery, crank position sensor. Was a quarter tank of gas, now its half tank, I added new gas and octane booster.
Crank Position Sensor: i tested the old one (Ohms B=>C), multimeter on 20k, it read 10+. New one tested 3.someting. I think that was a good choice to replace.
Battery: bought a new battery today, old one tested bad, cleaned the wires and terminals (aftermarket terminals), and pulled off the ground next to the battery and cleaned that off too.
Fuel Pump: I've done nothing here. I hear it turn on when the key goes to accessory. I dont have a stethoscope and there is a shield over the tank so i dont really hear it pumping after that.
Codes: I dont have a ODBII reader, but i turned the key on-off-on-off... It read 12 (battery disconnect i think) and 55? Dont knwo what that means.
TLDR: Replaced distributor cap, button, plugs, plug wires, battery, and crank position sensor. Whats next?
Anyway, i'm not a mechanic. I dont have more than a few hours to spend on this at a time. i'm just looking for what the next reasonable thing to look into will be.
Thanks in advance for any advice!
BBZJ is offline
post #2 of 7 Old 08-17-2013, 06:09 PM
ZeeJay1997
got spark?
ZeeJay1997 is offline
post #3 of 7 Old 08-17-2013, 07:15 PM Thread Starter
BBZJ
Actually, no I just checked.
BBZJ is offline
post #4 of 7 Old 08-17-2013, 07:51 PM
ZeeJay1997
given everything you've posted, I suspect you have a bad coil. Do you have a meter?
post #5 of 7 Old 08-18-2013, 12:38 AM
Oldfrog
2007 WK
No spark?
Check ASD fuse under the hood.
Before you replace it, you might as well check the o2 sensor wires at the cat. They wrap around the drive shaft and pop that fuse. Pretty common.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #6 of 7 Old 08-18-2013, 05:23 AM Thread Starter
BBZJ
@ZeeJay1997
I have a meter. I'll read up on testing it and add that to my list. Any tips there?
@Oldfrog
I'll check ASD as well, and definitely the o2 at the cat. It actually has been shredded by the drive shaft once already.
BBZJ is offline
post #7 of 7 Old 08-20-2013, 07:00 PM Thread Starter
BBZJ
It was the ignition coil. Swapped it out and started right up.
Never really figured out how to test it though. Instructions from my chiltons were not helpful. And the youtubes were more interested in yapping about which multimeter was best so i couldnt make it through the whole thing
Anyway, thanks for all the input. Now I can get on to more interesting work!
BBZJ is offline
