Stalls When Put in Gear - JeepForum.com
post #1 of 11 Old 08-05-2013, 09:33 AM Thread Starter
dangeo
1996 Grand Cherokee
4.0L
Inline 6
A few days ago i was driving and the engine started running really rough. it then felt as though it was losing power (i floored it and was barely able to maintain current speed) when i took my foot off the gas it stalled immediatly and would not restart. i towed it home and replaced the crankshaft position sensor and it started up, however it was still running really rough. i thought it was a misfire problem so i changed the plugs and wires. that seemed to fix the rough running. now i can start it and it is fairly smooth (still seems a little rough) and it will run just fine untill i shift into drive or reverse. when i do it stalls and shuts down. im at a loss for what to do next. i have had the alternator tested and it was good. the battery is a month old and still good. any ideas?
dangeo is offline
post #2 of 11 Old 08-05-2013, 11:04 AM
Rich93ZJ
Did you use a Mopar sensor? Did you disconnect the battery? Possible prob with your Neutral safety switch
Rich93ZJ is offline
post #3 of 11 Old 08-05-2013, 11:19 AM Thread Starter
dangeo
I used a Duralast crankshaft sensor.
Yes, I did disconect the battery for ten minutes after switching the sensor and before starting it up.
If it was the NSS wouldnt it not start in park. I can get it to start and run in park no problem, when I try to put it in gear it stalls out.
dangeo is offline
post #4 of 11 Old 08-05-2013, 11:59 AM
JasonStebbins
1. Only use Mopar sensors on a Jeep.
2. Check your transmission dipstick while running warm in neutral.
Poop
JasonStebbins is offline
post #5 of 11 Old 08-05-2013, 12:47 PM
ZeeJay1997
i gotta ask the obvious here... does your CEL work, as evidenced by coming on for 3 seconds when the key is in the ON position; and if you know it works, did it come on during any of drivability issues?
ZeeJay1997 is offline
post #6 of 11 Old 08-05-2013, 12:51 PM
Oldfrog
2007 WK
Ditto on the Mopar crank sensor.
Otherwise, right now, I'm leaning towards the IAC, TPS , a dirty throttle body, or even a bad vacuum leak. The TPS is sometimes the culprit when it doesnt want to "go" while driving, no matter how much gas pedal you give it. But let's not go replacing sensors until we narrow it down.
As Jason said, I'd start by checking the tranny fluid, then I'd clean the throttle body and IAC.
Go ahead and pull the codes too.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 11 Old 08-05-2013, 12:56 PM Thread Starter
dangeo
The CEL isnt comimg on.
Trans fluid is good.
How do you check the TPS?
dangeo is offline
post #8 of 11 Old 08-05-2013, 06:57 PM Thread Starter
dangeo
Dont know if this is related, but I just found some oil on the air filter.
dangeo is offline
post #9 of 11 Old 08-05-2013, 08:07 PM
JeepNicholson
Your CCV system is clogged somewhere, or you have a vacuum leak as mentioned above.
Both could cause oil on the air filter. You can remove those elbows on the valve cover and see how gooey they are - they should be clean. The elbow in the back is almost like a pinhole inside and is prone to clogging. Be careful removing them as they are somewhat easy to break, you may want to try to warm up the engine if you can to soften the elbow gaskets first. Look in the elbow holes the valve cover too - if it's really gross in there it may be a good idea to take it off and clean it so your engine can breathe, and maybe throw on a new valve cover gasket too while you're in there
JeepNicholson is offline
post #10 of 11 Old 08-07-2013, 11:50 AM Thread Starter
dangeo
Well, that was it. Clogged ccv.
Thanks for all the help everyone.
dangeo is offline
post #11 of 11 Old 08-07-2013, 11:59 AM
JeepNicholson
Well hot damn! Glad it worked out!
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
cps , rough idle , stalling
