stalls - JeepForum.com
post #1 of 2 Old 02-18-2010, 07:08 PM Thread Starter
toolman401
1976 CJ7
stalls
I have a 96 ZJ with a 5.2L try to start it won't start hold the throttle a little starts right up let go of the throttle it stalls. turned the idle stop screw in to get it to run now it surges do i have a bad throttle position sender no codes are set.
toolman401 is offline
post #2 of 2 Old 02-18-2010, 07:19 PM
ZJ5point2GCL
its an idle air issue, the screw you turned just keeps stress off of the actual butterfly in the throttle bore, when the throttle is closed. so turn the screw back. then search IAC valve, its either dirty or bad, very common
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
94 4.0 stalls pettit5 ZJ Grand Cherokee Forum 15 09-09-2013 06:52 PM
4.0 sometimes stalls... christine1003 ZJ Grand Cherokee Forum 7 12-23-2009 05:26 PM
Please HELP my 95 Zj stalls wrestlerobx ZJ Grand Cherokee Forum 43 05-18-2008 09:58 PM
93 ZJ stalls robin58 ZJ Grand Cherokee Forum 3 01-22-2007 06:27 PM
Zj Stalls!!! joeyschribar ZJ Grand Cherokee Forum 13 04-11-2006 05:18 PM
