Stalling and rough idle.. - JeepForum.com
post #1 of 14 Old 05-17-2013, 04:53 PM Thread Starter
GThompson51
1998 Jeep Grand Cherokee
4.0L Automatic
It didn't start one day so through a very long process of trial and error, I replaced the cam shaft sensor, ignition coil and the crank shaft sensor. The problem actually was the cam shaft sensor and it ran fine.
That was a few weeks ago, now she's idling really rough and stalling out. The code I pulled was P0320 but I just replaced the crank shaft sensor. My buddy noticed that the pulley for the a/c compressor isn't spinning the full time and belives that is the answer.
Figured I'd get some opinions.
Thanks!
GThompson51 is offline
post #2 of 14 Old 05-17-2013, 05:16 PM
dusterdude
What brand crank sensor?if it wasnt mopar,get your money back and buy a chrysler sensor
dusterdude is offline
post #3 of 14 Old 05-17-2013, 05:19 PM Thread Starter
GThompson51
I think it was duralast. Do they go bad that frequently?
post #4 of 14 Old 05-17-2013, 06:39 PM
txbass06
Most of our Jeeps are picky when it comes to sensors and tend to like Mopar over anything else
txbass06 is offline
post #5 of 14 Old 05-17-2013, 07:43 PM
dellis
2005 WK
That's normal. The "spinning" only happens when the compressor is compressing.
The P0320 code plus the symptoms you describe indicate that you either have a bad Crankshaft Sensor, the connector is not fully seated, or the wiring was damaged somehow during your installation.
dellis is offline
post #6 of 14 Old 05-18-2013, 10:00 AM Thread Starter
GThompson51
Thanks, I took a look at the wiring and it doesn't appear damaged, It is still tight in the hole. I guess I'll go return the sensor and exchange it.
post #7 of 14 Old 05-18-2013, 11:17 AM Thread Starter
GThompson51
Is it dangerous to drive it like this?
post #8 of 14 Old 05-18-2013, 12:03 PM
JohnCrabtree
1994 ZJ
Yes. You loose your brake booster and power steering if it dies.
JohnCrabtree is offline
post #9 of 14 Old 05-18-2013, 12:27 PM Thread Starter
GThompson51
I had an 89 Wrangler that wouldn't stay on and got pretty good and two footing it, neutral at stop lights etc.
My ZJ only stalls out during decel and idle. Is there risk of further damaging any additional parts?
post #10 of 14 Old 05-19-2013, 12:31 AM
Oldfrog
2007 WK
"...My ZJ only stalls out during decel and idle."
Sounds like the IAC needs clean
ing and/or replacing.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #11 of 14 Old 05-19-2013, 01:47 AM
AaronButler
You are positive that its the pulley on the AC compressor? The air compressor will not spin all the time, only when the pressure gets low, and will constantly be turning on and off while the car is running (and AC turned on). The pulley, however, needs to be spinning all the time.
1996 ZJ 4.0 Laredo... you know, the one with the ripped leather seats
AaronButler is offline
post #12 of 14 Old 05-20-2013, 10:06 PM Thread Starter
GThompson51
Thanks for all of the replies! The problem was that the crank shaft sensor was about a quarter turn loose. I tried to wiggle it with my hand and it didn't move but I tightened it anyway and sure enough she's purring right along.
post #13 of 14 Old 05-20-2013, 10:07 PM Thread Starter
GThompson51
I'm going to look into cleaning the IAC anyway, that sounds like a good thing to do regardless.
post #14 of 14 Old 05-20-2013, 10:09 PM Thread Starter
GThompson51
The AC pulley itself is spinning but not the compressor. I thought it only spun when in use but I wasn't certain.
1998 , p0320 , stall , stalling , zj
