stalling not starting up date - JeepForum.com
post #1 of 4 Old 07-19-2003, 08:42 AM Thread Starter
wyatterp22
stalling not starting *up date*
I would like to start off by saying thank you for all the help. I think we have narrowed it down. It took a while and alot of aggervation. Well the fuel pump isnt bad. So we checked the ingiton coil not that either. There is no power for the coil to the plugs. We replaced the camshaft sensor(had a crack in it) still nothing. We replaced the rotor in the distrubitor(just looked bad) and nothing. After all that we narrowed it down to the crankshaft sensor which after hooking it up the a reader came back with all weird and wrong readings. So that is the less agervating version for you guys. I will up date again after we put in the crankshaft sensor.
wyatterp22 is offline
post #2 of 4 Old 07-21-2003, 08:19 PM Thread Starter
wyatterp22
Ok here is the conclusion to the problem. After all said and done the problem was the crankshaft sensor(49.00 auto zone). Just for peoples ref if you dont get spark on the plugs and no juice at the ignition coil start looking at the crankshaft sensor hook it up with an ohm meter and check the resistance. Also the code for this problem is 11. If you dont have a chilton book you should get one it helped out . Once again thanks for all the help and i hope this helps someone else. wyatterp22 95 gc limited
post #3 of 4 Old 07-25-2003, 11:31 AM
Zeff
Hey, you posted in my thread about a similar problem.
We checked the crankshaft sensor but it was reading 'close to 8volts' like our manual says.
We also have power in the ignition coil and power to the distributor. All of the wires have continuity but there is no spark.
Is there a different way to check the crankshaft sensor?
Zeff is offline
post #4 of 4 Old 07-26-2003, 04:08 PM Thread Starter
wyatterp22
you can check the camshaft sensor there in the distruabtor and the rotor. we didnt get any power any place with the crankshaft sensor out. see if that helps any
97 ZJ Stalling and Hard Starting kontrast ZJ Grand Cherokee Forum 11 11-10-2011 08:25 AM
Help with my 96 GC stalling and starting right back up. jboner ZJ Grand Cherokee Forum 2 01-20-2010 03:57 PM
Front Driveshaft CV starting date in WJ's? mrtosh ZJ Grand Cherokee Forum 3 10-06-2009 04:10 AM
starting/stalling issue chrisstromberg ZJ Grand Cherokee Forum 18 01-06-2009 05:45 PM
5.2L stalling and hard starting mudder1_2000 ZJ Grand Cherokee Forum 4 12-18-2008 07:10 PM
