Stalling on freeway. - Page 2 - JeepForum.com
post #16 of 27 Old 04-02-2013, 11:50 AM
Ruby3
Sounds good. Ill have to add that to the build sheet
Ruby3 is offline
post #17 of 27 Old 04-09-2013, 02:28 AM Thread Starter
sergio
Plenum replacement gave me power but I still have that stall on the freeway. I'm stumped!
sergio is offline
post #18 of 27 Old 04-09-2013, 09:50 AM
ilive4cars0122
Check the ignition coil yet?
ilive4cars0122 is offline
post #19 of 27 Old 04-09-2013, 02:16 PM Thread Starter
sergio
No not yet. I was last night but isn't the ignition coil work to only turn on the jeep?
sergio is offline
post #20 of 27 Old 04-09-2013, 06:48 PM
ilive4cars0122
The ignition coil gives the spark to a wire that runs to your distributor. Then distributor then supplies that spark to each individual spark plug wire making it to the spark plugs. I think u can understand what happens next.
post #21 of 27 Old 04-30-2013, 11:25 PM Thread Starter
sergio
So quick update. I changed the ignition coil but it made no difference at all. It still hesitates on freeway like its cutting gas. I have no idea what else to change. My last bet would be a clogged cat or fuel pump. Ehhh.
sergio is offline
post #22 of 27 Old 05-01-2013, 03:16 AM
Rich93ZJ
Have you tried swapping the fuel pump relay yet. May have a flaky relay. If that doesn't do it, I would check the fuel pressure as stated in a previous post. G/L. Keep us informed.
Rich93ZJ is offline
post #23 of 27 Old 05-03-2013, 12:28 AM Thread Starter
sergio
Would you happen to know where i would be able to get a new pump relay for a good price?
sergio is offline
post #24 of 27 Old 05-03-2013, 04:16 AM
ZeeJay1997
Swap it out with another relay from the PDC
ZeeJay1997 is offline
post #25 of 27 Old 05-04-2013, 03:43 AM Thread Starter
sergio
I changed the relay. Doesn't do it as much, but its still there. Seems to go away every time I switch something out but comes back every time. I haven't done the fuel pressure check yet, but im going to try the soap and water trick. As of now im not driving it until i figure what it is. Sucks because i have my lift ready to be put in.
sergio is offline
post #26 of 27 Old 05-05-2013, 08:12 PM
papitt
I bought a fuel pressure gauge set up from Harber Freight not long ago it was only about 18.00 of maybe 25.00 But cheap.
papitt is offline
post #27 of 27 Old 06-23-2013, 05:51 PM Thread Starter
sergio
So finally came to checking the fuel pressure and it's reads fine. Anymore possible ideas why? I've changed everything. Would a crankshaft do the fix?
sergio is offline
