SQUIB? what's a SQUIB? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > SQUIB? what's a SQUIB?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 11-11-2006, 12:17 AM   #1
CallMe"Mcgyver"
For a while my Air Bag light has been coming on randomly and the jeep will chime at me. So a good buddy of mine plugged in his Snap-On "Solus" scan tool and it came out with this:
DRIVER SQUIB #1 CIRCUIT OPEN
we both looked at each other and said "what the heck does 'SQUIB' mean?"
We didn't have the time to start checkin every sensor on the driver's side, so I wrote it down and I'll have to work on it a bit later.
But does anyboby at all know what that means?
--Paul
Integrity is who you are when no one is looking.
It's a stock WJ, but give me time. ...Maybe some money too?
A sketch of what I'm kinda building towards
CallMe"Mcgyver" is offline   Reply With Quote
Unread 11-11-2006, 12:37 AM   #2
toke
I_R_Food
toke's Avatar
You need what is called a "clockspring." It is an electrical component that carries the signals from the steering wheel controls and airbag through the rotating wheel to the steering column wiring harness.
http://www.faqs.org/qa/qa-6666.html
dont know what a squib is though
i take that back i found this def on google
"A Squib is someone who was born into a wizarding family but hasn’t got any powers"
hope that helps
1995 YJ gone as well
2001 Grand RIP
2004 Rubicon RIP
toke is offline   Reply With Quote
Unread 11-11-2006, 12:43 AM   #3
Texas WJ
Texas WJ's Avatar
2005 WK
A squib is a small explosive device which has a wide range of uses, such as generating mechanical forces as well as in pyrotechnic use. A squib can range in size from 2 to 15 millimetres in diameter. The squib, being an explosive device, releases a lot of energy, and can be used for shattering, triggering, propelling and cutting a wide range of materials.
http://en.wikipedia.org/wiki/Squib_(explosive)
Basically, a squib is used to deploy the airbag.
http://www.asashop.org/autoinc/dec2002/collision.cfm
Texas WJ is offline   Reply With Quote
Unread 11-11-2006, 02:11 AM   #4
Woody
Retired back to Bowties
Woody's Avatar
1985
Squibs are not something to play with. We use them on airplanes to activate the fire extinguishing system of the engines.
Didn't realize they used the same thing in the airbag. Makes sense though.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
