Squeeky noise coming from A/C Compressor??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Squeeky noise coming from A/C Compressor???
Raceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearTJ Dana 60 - BOLT IN REAR
Unread 02-11-2005, 10:07 AM   #1
FullForceSound
Howdy folks,
I've noticed within the last week that I'm starting to get a little noise coming from what seems to be my A/C compressor near that back of the unit, I've tried spraying a little bit of WD-40 lubircant but the squeeky noise is still there. Has anyone ever heard of this? If so does it sound like I need to get my A/C compressor serviced/replaced? It doesn't get any louder or lower with the A/C on or off. Could it be the belt? I don't see any cracks or splits, It's not very loud but it's really getting to be annoying!! HELP!!!!
Thanks in advance,
-Sam Costa
FullForceSound is offline   Reply With Quote
Unread 02-11-2005, 10:51 AM   #2
pushead
Originally Posted by FullForceSound
Howdy folks,
Thanks in advance,
-Sam Costa
First of all you should know WD40 is not a lubricant. It is a cleaner. Read the can. It could be the pully or even the clutch. Unless it drives you crazy I would not worry about it unless you can do your own a/c work and replace the compressor.
Its not a jeep if it dont have 4wd.
pushead is offline   Reply With Quote
Unread 02-11-2005, 01:32 PM   #3
Othoni
It sounds like the ac compressor or the clutch, if you don't know how to change any a part off the ac system I would advice to 1)get a Haynes manual and read up on it or 2)go to a reputable mechanic and have them change whatever part is broken. If you plan on working on the ac system I would strongly advice to be careful when draining the freon out of the system and then flush the system out so there's no debri that can clog it up.
[B][COLOR=Navy]00 WJ I6 4.0L 4x4,
FIPK Gen2,Borla Exhaust Magnaflow tip, Carsound Cat, 62mm TB,Alarm/Remote start,Tinted windows,Front and rear tow hooks,Hypertech programmer3. Addco rear and front sway bar, Hid's 8500k[/COLOR][/B]
[URL]http://www.cardomain.com/id/othoni[/URL]
Othoni is offline   Reply With Quote
Unread 02-11-2005, 10:43 PM   #4
oct7brian
Also you might want to check out your alternator bushing and idler pulleys. They can make a noise that echos in the engine compartment making you think its something else like the AC Compressor.
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline   Reply With Quote
