Squeaky suspension?!?! - JeepForum.com
post #1 of 11 Old 03-25-2005, 07:15 AM Thread Starter
JCDubya
2009 WK
This is bugging me. My suspension squeaks!! I think it's mostly the front. Whenever I go over some bumps it does it. Does anybody have an idea of what it could be?
JCDubya is offline
post #2 of 11 Old 03-25-2005, 07:21 AM
Derek33
Derek33's Avatar
I know my suspension used to make an "eeking" noise when i went over a bump (more so when it was cold out), but if its a short high pitched sqeak, it could be your front sway bar bushings.
Derek33 is offline
post #3 of 11 Old 03-25-2005, 09:39 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
There is a service bulletin out on the problem. I had mine fixed under warrenty. You can go to wjjeeps.com and check it out. I don't remember the bulletin number, sorry.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 11 Old 03-25-2005, 10:48 AM Thread Starter
JCDubya
2009 WK
I didn't see anything listed on WJJ pertaining to squeaky suspension...
JCDubya is offline
post #5 of 11 Old 03-25-2005, 11:30 AM
gregmondro
gregmondro's Avatar
bushings would be the first culprit i'd think
also, when was the last time you greased?
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #6 of 11 Old 03-25-2005, 11:33 AM Thread Starter
JCDubya
2009 WK
Me personally, never... I've only had the Jeep for a couple months. The only thing i've greased are the new bushings on my Addco rear anti-sway bar.
JCDubya is offline
post #7 of 11 Old 03-25-2005, 11:50 AM
gregmondro
gregmondro's Avatar
there are a few things up in the front that you can grease, i'd give it a shot. Who knows
post #8 of 11 Old 03-25-2005, 12:53 PM
KC8RXQ
JGC squeaky suspension
Try this web site out. It's the actual TSB posted on WJJeeps.com
http://www.wjjeeps.com/tsb_list.htm#0200204a
The front suspension on my 2004 JGC is doing the same thing. The Jeep Service Manager knew exactly what I was describing over the phone and as a result, I have an appointment to take it in on Monday morning.
Good luck on getting the problem fixed and enjoy the Jeep.
Ed/KC8RXQ
2000 JGC Laredo 4.0L/Selec-Track (stock)
2004 JGC Limited 4.7L Quadra Track II (stock)
but someday.........
KC8RXQ is offline
post #9 of 11 Old 03-25-2005, 02:13 PM Thread Starter
JCDubya
2009 WK
Thanks! I was looking in the wrong spot. I also saw a bulletin for "wind like sound at top rear corner of front door" which is bugging me too. While I'm at the shop, I need to get a key programmed, I only have one so I can't do it myself. What's the stealership charge to do this?
JCDubya is offline
post #10 of 11 Old 03-28-2005, 10:13 AM
jwneural
I have the same problem....
Especially in cold weather. I cannot access the TSB link you gave. Is the site down?
Can you briefly describe what it said?
Many thanks
'99 GC Laredo 6cyc 48k miles... and still loving it
jwneural is offline
post #11 of 11 Old 03-28-2005, 12:44 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Lube the swaybar bushings. The squeak will go away.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
Squeaky sound from engine? Sounds like squeaky shopping cart. Not serpentine belt 3xX ZJ Grand Cherokee Forum 15 11-25-2008 05:06 PM
Squeaky WJ Suspension MuXi115 ZJ Grand Cherokee Forum 4 04-09-2007 09:04 PM
Squeaky Squeaky in reverse rossj711 ZJ Grand Cherokee Forum 2 10-10-2006 03:08 PM
squeaky suspension! fiddlyD ZJ Grand Cherokee Forum 16 01-22-2005 08:52 AM
Squeaky Jeep Metz Motorsport ZJ Grand Cherokee Forum 2 09-09-2004 12:37 AM
