Squeaking noise coming from behind dash - JeepForum.com
post #1 of 10 Old 08-02-2006, 10:20 AM Thread Starter
oneillsean
I have an irritating squeaking noise coming from inside the dash at 20-60 mph. It seems to occur more when the wheels wobble (especially at between 40-50 mph) but also occurs at other speeds when driving on a rough road or hitting a bump. Doesn't sound like a speedometer cable (I'm not even sure the '96 ZJ's have speedo cables anymore). I bought some silicone lubricant spray and tried spraying any metal to metal contact areas that were accessible without taking off the dash/instrument panel. There don't seem to by any loose screws. I can only stand covering the squeaky noise with the radio for so long before my ears need a rest.
Was curious if anyone else had this problem.
Also curious how big a job it is to take off the dashboard so I can start spraying lube on squeak culprits. I.e., is there anything to watch out for or parts that are needed before tearing out the dash - this is my daily driver so I can't afford to have it sit overnight while I run to the dealer to buy parts.
Any help is appreciated.
oneillsean is offline
post #2 of 10 Old 08-14-2006, 01:13 PM
jdenzer
Had the same problem. I have taken the front bezel for the instrument panel off several times, to install/replace the radio. While driving I noticed an annoying squeaking comming from the dashboard. Started pressing and holding parts of the dash while driving to isolate the noise. Turned out to be the front instrument panel bezel. Behind the bezel there a tiny nipples w/ rubber caps that keep the bezel from rubbing against the inside of the dash. Your nipples might be missing the rubber caps or broken. I would check that.
jdenzer is offline
post #3 of 10 Old 08-16-2006, 10:46 AM Thread Starter
oneillsean
Thanks for the advice. I'll check it out.
post #4 of 10 Old 08-24-2006, 05:42 PM Thread Starter
oneillsean
Took almost the whole dash out including all bezels, instrument panels, knee panel, glove box, dashboard, defroster shield...everything short of the whole metal support structure that bolts to the firewall. I tightened all accessible screws and bolts and sprayed silicone lubricant over any part that could conceivably cause the noise. But the squeaking noise is still there.
I'm curious how difficult it is to take out the metal support and take off the heater/AC stuff? Anyone ever try it?
post #5 of 10 Old 08-24-2006, 05:48 PM
greasefingers
greasefingers's Avatar
1994 ZJ
So I take it your nipples where not getting chafed
Removing the HVAC is am all day job. I would only attempt it during the weekend just in case it takes longer.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 10 Old 08-24-2006, 08:48 PM
JamesEric
This is a long shot but I had the same problem. It turned out to be the Tranny dipstick. It just needed to be pushed down in the tube. This was on my '94 JZ 5.2.
JamesEric is offline
post #7 of 10 Old 08-24-2006, 10:55 PM
joeyschribar
ive got that problem, this MOST LIKELY isnt it, but give your air intake houseing a shake, see if it squeaks, hahaha, you never know, it may and if so, tighten down thoose bolts!
joeyschribar is offline
post #8 of 10 Old 09-13-2006, 06:48 PM Thread Starter
oneillsean
No chafed nipples...
Apparently my nipples are not chafing - not on the instrument bezel anyway.
Thanks for the advice on the HVAC, and for checking out the air intake and the tranny dipstick. I'll check those next.
post #9 of 10 Old 04-04-2013, 10:39 AM
Easywolf32
2006 WK
Hi,
I have the exact same squeeking problem coming from somewhere inside the dash I am sure. It definitely does not feel as if it's coming from underneath the car or inside the engine. Does anyone know what the heck is this noise??
Easywolf32 is offline
post #10 of 10 Old 04-04-2013, 04:25 PM
KoreaZJ
1994 ZJ
Push in/out slightly along the top edge of the plastic cluster window, hear a squeak? Push in, wedge a couple of toothpicks in the crack where it squeaks the most, see if it stops. This is a problem on many vehicles, not only Jeeps.
KoreaZJ is offline
Loud Squeaking Coming From Rear End ZJeepMI ZJ Grand Cherokee Forum 7 06-14-2011 09:35 PM
ZJ serpantine belt squeaking/coming off issues paradoxgdf ZJ Grand Cherokee Forum 7 04-12-2011 02:11 AM
Squeaking sound - sounds like its coming from front driveshaft ujoint assembly _Kyle_ ZJ Grand Cherokee Forum 17 02-28-2011 09:27 PM
Squeaking Soung Coming From Front Wheels rockon1202 WJ Grand Cherokee Forum 8 06-29-2010 09:08 PM
squeaking sound coming from right front wheel? RMF001 ZJ Grand Cherokee Forum 13 09-27-2007 01:17 PM
