Squeak! Squeak! Squeak! - JeepForum.com
post #1 of 5 Old 09-11-2007, 07:15 PM Thread Starter
WiLieR
99WJ. It's driving me nuts! The back driver's side axle emits a constant "squeak squeak squeak" sound as it rolls along. It is speed sensitive (occurs more often as speed increases) and does so if the brakes are applied or not applied. At first I thought it was the rear brakes squeaking away, so I did the usual stuff; anti-squeal on the back of the pads, made sure everything was tight, checked the rotors to see if they were warped. None of this has affected this squeak. I completely ruled out brake squeak today as I drove down the side of Lowes and listened to the squeaker and applied the brake in a moderate fashion. It squeaked till it came to a complete stop, the same squeak squeak squeak it has been doing.
There are no signs of any metal to metal contact at all on anything that rotates back there. I looked at the backing plate (dust shield), the e-brake shoes, inside the rotor where the e-brake applies, behind the axle shaft hub, everywhere I could think of to look and even checked out the studs in the axle to make sure all of them were tight. I have tried putting the WJ in the air and listening while it was in drive, but unless the rear has weight on the tires there is no squeaking at all. I rotated the tires hoping it was the tire making the noise but the squeak didn't move to the passenger side front. Unless I have a family of mice going for a joy ride in my rear tire then I am out of ideas. Anyone else able to point me in a new direction?
99 WJ Laredo - Mine once again!
WiLieR is offline
post #2 of 5 Old 09-11-2007, 11:26 PM
Gerald K4NHN
If the Squeak is faster than the tire rotation, check the rear U-joint
Gerald K4NHN is offline
post #3 of 5 Old 09-12-2007, 08:55 AM
ynotyj
ynotyj's Avatar
Check with Yardman Harry. I think his squeak turned out to be a mouse.
His: 1996 ZJ, 4.0 Selec-Trac
Hers: 1993 ZJ Woody 5.2
Ours: 2004 Chrysler Town & Country Touring. Sweet.
Previous Jeeps: 86 XJ, 92 XJ, 95 YJ, 87 YJ
ynotyj is offline
post #4 of 5 Old 09-12-2007, 09:08 AM
Yardman Harry
O
Yardman Harry's Avatar
A mouse trap cured that real fast!
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #5 of 5 Old 09-12-2007, 09:40 AM
rflem550
Sounds like an issue I had with my 02. Turned out to be a bad axel bearing that i had to have replaced. Mine was in the front though...
rflem550 is offline
Squeak squeak goes the jeep.. -Joe- ZJ Grand Cherokee Forum 13 06-04-2013 08:30 PM
*squeak*squeak* 97DCZJ ZJ Grand Cherokee Forum 1 06-11-2009 10:27 AM
94 ZJ has a squeak NEp8ntballer ZJ Grand Cherokee Forum 14 04-28-2008 08:08 PM
Squeak! Squeak! Squeak! KDH ZJ Grand Cherokee Forum 6 03-05-2007 12:44 AM
Squeak Daveeycrocket ZJ Grand Cherokee Forum 3 12-20-2004 01:47 PM
