Squeak squeak goes the jeep.. - JeepForum.com
post #1 of 14 Old 07-10-2008, 02:54 PM Thread Starter
-Joe-
-Joe-'s Avatar
Just recently i noticed a really annoying squeak somewhere under the jeep. I have lubed everything, bushings, springs any spot that I could imagine could or would be able to make a squeak. Just recently hit 273k miles too.
It happens more when the rear suspension moves, just riding down the road with the normal variations of the road it will squeak. Its not a constant squeak so its not a bearing or wheel issue.
I know its impossible to diagnose noises over the net but all I want is some suggestions on something that mabye I missed.
I did notice my transmission mount is a little worn so ill replace it next week.
The only suspension parts that have not been replaced is the rear track bar and I do have a energy suspension poly kit for it i just never got around to changing it out. (my luck thats what it is)
Any thoughts?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #2 of 14 Old 07-10-2008, 02:55 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
turn up the radio....works every time for me.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 14 Old 07-10-2008, 02:58 PM Thread Starter
-Joe-
-Joe-'s Avatar
not an option.. Somethings not right
- Joe -
-Joe- is offline
post #4 of 14 Old 07-10-2008, 03:07 PM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Try the linkage for the TC. I had mine squeak and spraying some lithium grease solved it.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #5 of 14 Old 07-10-2008, 04:44 PM Thread Starter
-Joe-
-Joe-'s Avatar
Ill check that out..
I cant make the jeep recreate the sound when not moving which sucks.
Even at a low speed going from the street over the lip of the driveway causes it to squeak..
- Joe -
-Joe- is offline
post #6 of 14 Old 07-10-2008, 04:55 PM
2003tjxcr
tj squeak
i put a skyjaker double flex kit in my 03 tj and the heim joints are squeaking does any know of a manufacturer besides skyjacker? i would like greasable ones
2003tjxcr is offline
post #7 of 14 Old 07-11-2008, 08:27 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
It was hard for me to recreate as well. If it was squeaking and I pushed on the TC shifter forward it would stop squeaking.
Jeep Sold! 02/2009
Need AMSOIL?
post #8 of 14 Old 07-11-2008, 01:15 PM
ZJTechie
If you havent tried this already, you could get someone to drive your jeep very slowly, as you walk around listening intently for the squeak. At the very least it could help you narrow the scope of where it's coming from.
ZJTechie,
My current JEEP score: 205 (see site below)
ZJTechie is offline
post #9 of 14 Old 07-11-2008, 01:22 PM Thread Starter
-Joe-
-Joe-'s Avatar
yeah.. it wasnt the linkage.
Louder today but im alone right now but my next step was to let someone else drive while i listened.
- Joe -
-Joe- is offline
post #10 of 14 Old 07-11-2008, 01:41 PM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
How are your shock bushings? Maybe the end links. How about your sway bar bushings? Something else to consider, how are your lift gate struts? Or the rubber stops on the lift gate? I had some squeaking from them.
Hard to diagnose.
Jeep Sold! 02/2009
Need AMSOIL?
post #11 of 14 Old 07-11-2008, 02:58 PM
Zoso
2005 WK
I have something similiar with my ZJ but it is more related to the front end. I've changed just about everything in the front end besides the front u-joints in the prop shaft, the sway bar link ends, and the ball joints. If you figure it out, please post your results here.
Mike - 1998 Jeep Grand Cherokee Limited V8
Zoso is offline
post #12 of 14 Old 07-14-2008, 08:19 PM Thread Starter
-Joe-
-Joe-'s Avatar
It got worse over the last few days.. enough to hear it inside even when the windows were up..
Turned out to be the passenger side lower shock bolt had worked its way just loose enough so the metal sleeve was squeaking against the mount.
Took it out, lubed it up and bolted it back down.. squeak is gone..
- Joe -
-Joe- is offline
post #13 of 14 Old 07-15-2008, 08:14 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Cool, glad you found the cause.
Jeep Sold! 02/2009
Need AMSOIL?
post #14 of 14 Old 06-04-2013, 08:30 PM
goinggonzo92
You know I have the same problem on my 92 jeep wrangler YJ (automatic)....could this be a related problem with mine? just curious
goinggonzo92 is offline
squeak! lateralus3 ZJ Grand Cherokee Forum 14 10-27-2009 04:45 PM
*squeak*squeak* 97DCZJ ZJ Grand Cherokee Forum 1 06-11-2009 10:27 AM
94 ZJ has a squeak NEp8ntballer ZJ Grand Cherokee Forum 14 04-28-2008 08:08 PM
my wj has a squeak BlueIceDragon ZJ Grand Cherokee Forum 9 01-14-2008 09:13 AM
Squeak! Squeak! Squeak! WiLieR ZJ Grand Cherokee Forum 4 09-12-2007 09:40 AM
