*squeak*squeak* - JeepForum.com
post #1 of 2 Old 06-11-2009, 09:01 AM Thread Starter
97DCZJ
*squeak*squeak*
I think it's coming from the bushings in my LCA's in the rear, and I think it's because I tightened the bolts too much at the unibody bracket. Could it be becuse they are to tight, or not tight enough?
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #2 of 2 Old 06-11-2009, 09:27 AM
sdowney717
you cant over tighten them and cause a squeak. The bushing itself is likely worn out. When you tighten the bolt in a bushing, it is simply securing the metal sleeve pipe of the pushing to the car frame bracket. You dont want the metal sleeve to move, the rubber bushing will reset itself around the sleeve. If the rubber wears out, I guess it could get loose against the pipe and squeak.
To make these last longer, people tighten the bushing bolt with the wheels on the ground or the axle tubes bearing the weight. But it will reorient itself anyway.
sdowney717 is offline
Squeak squeak goes the jeep.. -Joe- ZJ Grand Cherokee Forum 13 06-04-2013 07:30 PM
94 ZJ has a squeak NEp8ntballer ZJ Grand Cherokee Forum 14 04-28-2008 07:08 PM
Squeak! Squeak! Squeak! WiLieR ZJ Grand Cherokee Forum 4 09-12-2007 08:40 AM
Squeak! Squeak! Squeak! KDH ZJ Grand Cherokee Forum 6 03-04-2007 11:44 PM
Squeak Daveeycrocket ZJ Grand Cherokee Forum 3 12-20-2004 12:47 PM
