squeak! - JeepForum.com
post #1 of 15 Old 10-25-2009, 09:12 PM Thread Starter
lateralus3
1994 ZJ
squeak!
i have a squeak in my front end that gets louder and faster as i accelerate. its driving me nuts! any ideas?
lateralus3 is offline
post #2 of 15 Old 10-25-2009, 09:20 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Many ideas.
Not enough info.
Could be anything based on given info (or lack thereof)....
Go to any dealership or reputable shop.
Tell them 'My Jeeps squeaks', and see what kind of response you get...
'09 Rubicon
Kruzin is offline
post #3 of 15 Old 10-25-2009, 09:28 PM
Bama_WJ
Bama_WJ's Avatar
Does the sound change as you got over bumps in the road?
My first idea is hub assembly.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #4 of 15 Old 10-25-2009, 09:32 PM
befumo
Water pump?
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #5 of 15 Old 10-25-2009, 09:34 PM
madi05
i get the same squeak and found out it is the bolt with the rubber oring holding the air intake down by the fender, try wiggling it by hand and see if u hear it ,, i put some lube on it and tried tightening with now fix yet,lol
madi05
madi05 is offline
post #6 of 15 Old 10-25-2009, 09:45 PM Thread Starter
lateralus3
1994 ZJ
i know its not the airbox. it seems to start at about 5mph and bumps dont do anything to it. its a rotational squeak i just know it has to be somthing around the front wheels
post #7 of 15 Old 10-25-2009, 11:49 PM
Bama_WJ
Bama_WJ's Avatar
Jack one of the front tires up off the ground. Put one hand on the tire at 12 oclock and the other at 6 oclock. Try to move the wheel back and forth to see if it has any play in it. If it does, your hub assembly is on its way out. You could probably spin it by hand to make sure its that specific wheel thats making the noise.
Daniel
Bama_WJ is offline
post #8 of 15 Old 10-26-2009, 12:11 AM Thread Starter
lateralus3
1994 ZJ
how much does it cost to fix that?
post #9 of 15 Old 10-26-2009, 12:33 AM
Bama_WJ
Bama_WJ's Avatar
You can get a new timken hub assembly off rockauto.com for $75.
Daniel
Bama_WJ is offline
post #10 of 15 Old 10-26-2009, 12:44 AM Thread Starter
lateralus3
1994 ZJ
cool i just found a write up from arlo on the hub assembly and axle shaft. so it looks like i have another project to do
post #11 of 15 Old 10-26-2009, 01:05 AM Thread Starter
lateralus3
1994 ZJ
ill have to go buy a bunch of cans of pb blaster and blast those bolts
post #12 of 15 Old 10-27-2009, 01:56 PM Thread Starter
lateralus3
1994 ZJ
today i was driving along and listening to the wonderful squeak and i was thinking could the squeak be one of my ujoints on my front drive shaft?
post #13 of 15 Old 10-27-2009, 02:00 PM
Travis873o
that is a good possibility. the joint on my driveshaft went out and made a chirping sound. it wasnt the ujoint itself, but the "ball and socket" joint in between the double ujoint assembly.
FOR SALE: ZJ 231 bezel. 5.9 ZJ sound bar. 5.9 ZJ electric cooling fan w/ wiring/sensors/relays
Travis873o is offline
post #14 of 15 Old 10-27-2009, 02:34 PM
Bama_WJ
Bama_WJ's Avatar
Easy way of determining that is to just take the front driveshaft out and see if the noise goes away.
Daniel
Bama_WJ is offline
post #15 of 15 Old 10-27-2009, 04:45 PM
cdajeep
check you emergency brake--I swore it was passenger front hub, but having a buddy riding with me he said it was rear. I changed the parking brake and now no sweak.
cdajeep is offline
Squeak squeak goes the jeep.. -Joe- ZJ Grand Cherokee Forum 13 06-04-2013 08:30 PM
*squeak*squeak* 97DCZJ ZJ Grand Cherokee Forum 1 06-11-2009 10:27 AM
94 ZJ has a squeak NEp8ntballer ZJ Grand Cherokee Forum 14 04-28-2008 08:08 PM
Squeak! Squeak! Squeak! KDH ZJ Grand Cherokee Forum 6 03-05-2007 12:44 AM
Squeak Daveeycrocket ZJ Grand Cherokee Forum 3 12-20-2004 01:47 PM
