Spring spacers that keep the "raked" look VS. ones that level it out
#1 | |
I have Rusty's 2" spacers (not yet installed) but the front ones are actually about 1/2" taller. This is going to "level out" the Jeep which I don't particularly like. Does anyone make a 2" (or whatever is just barely enough to clear a 265/65-17" Revo + UC springs) that are the same height front and rear?
If anyone likes the leveled out look but has spacers that are the same height front and rear, would you like to trade?
#2 |
the spacers I installed on my jeep (tereflex) are the same size for the front and back. So the jeep has the same look just 2" taller. I am surprised that the front spacers are larger.
[COLOR=navy]---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---[/COLOR] [URL=http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNTcxOTAxNnM0MTNkZmQzMXk1NDE%3D.jpg]MY JEEP[/URL] |
#3 |
Yea it surprised me too. Someone correct me if I'm wrong but from the factory, isn't the front the same height as the rear? It just looks lower b/c of how the wheel wells are shaped? But when spacer manufacturers try to compensate for this it actually makes the front higher that the rear which is why to me, it just looks weird.
#4 | |
Should have stuck with Kev's like your sig says. They are the same, front and rear. Is there a safe way to remove some of the height without losing material integrity?
[COLOR=DarkOliveGreen]2004-WJ 4.0, Loredo Kevin's 2.5" BB 265/75R16 Goodyear AT/S Pro-Comp ES3000 shocks Westin Safari-Bar Maxtel 6" Off-Road lights 360? of Tint Thule Roof Rack Do my new seat covers count?![/COLOR] |
#5 |
Break it, Fix It!
Can ya switch em front to rear???
Phil
'95 ZJ Ltd. White 4.0L TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion |
#6 | |
#7 | |
As for the Up-country+2.5 BB. I thought I read around here somewhere that it would only equal about 3" total. Which, if I'm not mistaken, you can do without any probs. Though adj track MAY be needed. Anybody?
#8 |
Addicted to Boost.
I have U.C. springs on KOR 2.5" BB
Only other things I have are JKS Adj. Track Bar, OME SS and teraflex extended pump stops...
2007 VW GTI |
#9 | |
Oh, and not to get too far off topic....maybe you can return 'em and get Blaine's set-up....If I had it to do over I would have saved a bit longer and went bigger for the first mod. Ya know 'bout that hind sight stuff? ![]()
#10 | |
Addicted to Boost.
I just have 245/75/16 (31x10.5 bout) so I have no rubbing or clearance poblems at all... Next summer I want to add OME springs to the 2.5"bb to give me 4.5" of total lift. I will add front & rear LCA's and a few other things to safely run that lift... then I will go with a 285/75/16's!!! I gotta save the money 1st!
2007 VW GTI |
#11 | |
![]() I'm thinkin of going 3.5" springs and dumping the BB this winter. LCA's, Track bar and som Disco's....then I think I would be bulletproof. Aside from all the armor I would still need You just can't win once you start it......like crack.
#12 |
Addicted to Boost.
Before you just buy new springs consider that you already have spacers... The nice thing about them is you can pretty much make any size lift and safely incoperate your spacers (IF DONE RIGHT)... In my case getting OME springs with the spacers is cheaper that Tera 4" springs and OME springs are better and I will have .5" more lift...
2007 VW GTI |
#13 |
When I first said the fronts are 1/2" taller, I was going by what someone else said. Well I just measured mine. The fronts are exactly 2". When looking at the rear spacers from the sides they measure 2" but the bottoms of them (where the springs will seat) concave quite a bit which is what I don't like. I'm not sure what I should do. Would it be bad if I left the front spring isolators out?
#14 | |
Addicted to Boost.
2007 VW GTI |
#15 |
I guess I'll just live with it...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
