speedometer calibration - JeepForum.com
post #1 of 17 Old 09-28-2008, 07:14 PM Thread Starter
gregsteele1979
I just put larger tires on my 2000 WJ. How do I recalibrate the speedo? It has the quadratrac II transfer case. It is as simple as replacing a gear in the tcase? Do I have to pay the dealer to do it because it is computer related?
Thanks
gregsteele1979 is offline
post #2 of 17 Old 09-28-2008, 07:19 PM
salc1
i think u can do it, 2006 and up star scan@ dealer i have a chart some wear for the diffent color speedo drive ill see if i can find it tomarrow itll be w/ part numbers, if i cant find it i downloaded it from jp mag
salc1 is offline
post #3 of 17 Old 09-28-2008, 07:25 PM
salc1
new parts last longer, sometimes?
salc1 is offline
post #4 of 17 Old 09-28-2008, 08:41 PM
adgjqetuo
adgjqetuo's Avatar
Isn't that only good for ZJs?
Don't WJs have a different process?
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #5 of 17 Old 09-28-2008, 08:53 PM
mailforjon
mailforjon's Avatar
2005 WK
im almost positive thats for ZJs only. i had to do it in my old ZJ and it was a little plastic gear thingy that swapped out in like 20 min.
never heard of this for the WJ. isnt it done electronically?
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #6 of 17 Old 09-28-2008, 08:56 PM
adgjqetuo
adgjqetuo's Avatar
Yeah, I know for a fact that's for ZJs because I've done mine before using that table. It just struck me odd that it was brought up for a WJ...I think it's electronic too...
If my memory serves me right, something with the Anti-Lock Brake Sensors?
post #7 of 17 Old 09-28-2008, 09:36 PM
StrokedWJ
StrokedWJ's Avatar
The WJ gets its speed signal from the ABS tone rings on the axle shafts not the TC. Therefore, the aforementioned T-case speedo gear swap does not apply.
What size tires did you put on? The dealer can adjust your speedo to the largest tire size that came stock (maybe a little bit more, IDK) to get it a little bit closer, or your other option is the Superlift Speedo Recalibrator http://www.4wheelerssupply.com/catal...oducts_id/1762
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #8 of 17 Old 09-28-2008, 11:12 PM
tsconver
2003 WJ
A 31" tire and my speedo is perfectly calibrated to my GPS.
But rumor is that the Odometer will be reading low.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #9 of 17 Old 09-30-2008, 09:54 AM
adgjqetuo
adgjqetuo's Avatar
So how would he get this done? I called up some local Jeep dealerships and they said that they don't do that there.
Weird I thought?
post #10 of 17 Old 09-30-2008, 12:29 PM
moparrr07
they do, if they have a drb3 which the are required to do they can, they just dont want to, tell them to change your pinion factor
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #11 of 17 Old 01-05-2009, 03:44 PM
adgjqetuo
adgjqetuo's Avatar
So I took it to the Local Jeep Dealership, and they tried to re calibrate the speedometer for my new tires (245/70/17) and after 2 hours they came back saying they couldn't do it. They said the Pinion would only go so low, then reset to the factory default. They apparently tried multiple times...
He told me they set it to the lowest they could get it (which is less than half of what it should be with the new tires) and didn't charge me anything for it. I tried using my GPS to see how much better it was, but it still looked to be about 3mph off.
I don't care about the speedometer as much as the odometer displaying the wrong miles.
Any thoughts? Its not like I upgraded to HUGE tires, but even if I did...come on its Jeep...you would think it should be possible??
post #12 of 17 Old 01-08-2009, 01:08 PM
mlozano
Hello All.
I have the same problem.
I have a 2004 WJ Overland and have installed 33" tires. I need to reprogram the speedometer. How can i calculate the correct Ring/pinion and tire size setup?
In the dealer they can only adjust to some tire sizes a little larger than stock, but if i change to the larger tire size available in the computer and modify also the R&P Ratio maybe i can set up to the correct spedometer.
Anybody knows the available options for tires and R&P in the programmer?
Thanks
Mariano
Jeep Wrangler Unlimited JK Rubicon 2011 - V6 3.8 - OME 2.5" Lift - General Grabber's 35" - 17" AEV Beadlocks - Bumpers ARB - Warn M8000
UTV Polaris Ranger RZR 2008
mlozano is offline
post #13 of 17 Old 08-24-2009, 04:02 PM
Ryno_WJ
Reviving this thread in hopes someone knowledgeable can chime in...I just put 265/75R16 on my WJ Limited. I found this thread that states the electronic speedo on a WJ uses the ABS tone ring signal to generate the speedometer output.
Question is can the computer be programmed to adjust for the slower turning tires at a given speed? e.g. is the WJ computer programable to set a different parameter for rear axle ratio or ? to trick it into reading the ABS signal and generating an accurate speed output?
I saw the link for an inline translator, just trying to fix the speedo on the cheap.
Ryno_WJ is offline
post #14 of 17 Old 08-24-2009, 04:10 PM
tsconver
2003 WJ
a dealer can fine tune the speedo but huge differences can not be adjusted for. The only thing that will effect speedo on a wj is tire size, it does not care about transmission, tc or gear ratios since speed comes form the abs tone ring at the end of the axle. The only real fix is the programmable devices that go for about $250.
A few goodies
2006 Red Liberty
tsconver is offline
post #15 of 17 Old 08-24-2009, 05:53 PM
moparrr07
FALSE:
i have done it when i worked at the dealer, with a drb3 on a wj, you imput the rolling circumference and that into the drb, for tire size changes,
the reason dealers say they cant is because they have a bunch of old farts working there that dont know how to do math or know they wont get paid good for it so they say they cant- IT CAN BE DONE AT ANY DEALER
Speedometer Calibration options for larger tires? jason915 WK Grand Cherokee & XK Commander Forum 3 11-05-2009 07:33 AM
thermometer calibration? bfr WK Grand Cherokee & XK Commander Forum 7 02-19-2007 07:02 PM
Speedometer Calibration for Larger Tires cherokee04 ZJ Grand Cherokee Forum 10 04-08-2005 05:27 AM
DTE Calibration? LeeandTanja ZJ Grand Cherokee Forum 3 09-23-2004 01:32 PM
