speedo jumping and sometimes quits? - JeepForum.com
post #1 of 5 Old 12-08-2005, 05:33 AM Thread Starter
02Lightning
Anyone have any experance with this? Think this would be a speed sensor? If so can I just buy a new one and put it in or would I need to know what trans I have. Also how do I identify what trans I have? Thanks guys.
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 119,500 miles
02Lightning is offline
post #2 of 5 Old 12-08-2005, 05:35 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I would highly recommend you pick up a Haynes or Chilton's repair manual from the local auto parts store.
You'll be able to see and read exactly how to replace or repair your speed sensor.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 12-08-2005, 05:37 AM
Androoos
I would bet its the speed sensor. A Chilton or Haynes manual should show the exact location of the speed sensor, it's easy to change, it bolts right into the tranny. Just watch out for any fluid that may leak out. Best to do it when the car is cold.
You can always get a build sheet for your Jeep, it will tell you what tranny you've got.
I had the speed sensor go in my '93 a long time back, right before I sold it. It did the same exact thing you're describing. It's a fairly common problem with GC's, if I'm not mistaken.
2001 Jeep Grand Cherokee Limited 4.7L Selec-Trac: 2" Fat Bob's/BDS Coil Lift, Bilstein 5100 Monotubes, JKS Quick Discos, Rough Country 2.2 Steering Stabilizer, OEM Tow Hooks, Kenwood Excelon KDC-X890
Androoos is offline
post #4 of 5 Old 12-08-2005, 07:53 AM
wmm_16
My wife's Caravan had the speed sensor go bad, it was acting like that then it went into "limp" mode. That was a pain!
1996 Jeep Grand Cherokee Limited
4.0 I6 2WD
Clear corners
K&N Filter
Alpine head unit
Firestone Destination LE's
wmm_16 is offline
post #5 of 5 Old 12-08-2005, 09:47 AM Thread Starter
02Lightning
Cool! Thanks guys!
4.0 GC Quits running simsup ZJ Grand Cherokee Forum 7 10-23-2014 08:40 PM
ZJ 5.9 runs, quits & won't start...... IMin4Low ZJ Grand Cherokee Forum 2 03-10-2009 05:28 PM
idles down then quits nursematt ZJ Grand Cherokee Forum 1 11-07-2006 10:41 AM
engine quits :mad: zbigniew ZJ Grand Cherokee Forum 2 07-09-2005 01:41 PM
Starts & Quits--Sometimes? Herb Jenssen ZJ Grand Cherokee Forum 2 12-01-2002 01:56 PM
