speedo issues help please - JeepForum.com
post #1 of 4 Old 04-11-2011, 07:39 PM Thread Starter
camojeep95
My 95 zj I replaced the speed sensor in the tranny and still don't work once it get 2 10 mph from higher it just shuts off and throws my check engine light on and it stays at 0 sometimes it will come on when it shifts sometimes it don't and when its not working it won't shift into tthe last gear....and another thing I have a bad static noise coming from drive side tweeter amd door speaker loose wire maybe? And advise on my issues?
camojeep95 is offline
post #2 of 4 Old 04-11-2011, 11:17 PM
jnicewan
Vehicle speed sensor is on the back of transfer case for 4x4's and extension housing (behind o/d unit) on 2wd's.
Loose or broken wire is possible, the tweeter wiring is spliced into the LF speaker wiring behind the dash, could possibly be the radio or amp I guess.
jnicewan is offline
post #3 of 4 Old 04-12-2011, 07:54 AM Thread Starter
camojeep95
I already replaced the speed sensor I'm point to try the ones in the wheels next and the spear I tried balancing to the d
Pass side and it still does it in the driver side
post #4 of 4 Old 04-14-2011, 08:57 AM
droopydawg
2015 KL Cherokee
I had a similar issue. I even thought it was the speed sensor too, and replaced it. Turned out, it was one soldiered connection inside the speedo itself that had worked itself loose. I took out the speedo unit (took about an hour) and took it to a speedo specialist and he had it working in about 30 minutes. $100.
droopydawg is offline
zj
High RPM issues and tranny issues Jeep Kid ZJ Grand Cherokee Forum 3 01-26-2010 04:09 PM
04 GC hvac issues-blower motor and other issues nation1979 ZJ Grand Cherokee Forum 1 09-02-2009 09:47 PM
++FIXED++ overdrive and speedo issues! mattready ZJ Grand Cherokee Forum 0 02-19-2009 08:09 PM
Speedo off by 10% cw8 ZJ Grand Cherokee Forum 8 09-11-2007 06:28 AM
Speedo help Decipticon ZJ Grand Cherokee Forum 4 05-04-2005 11:26 PM
