Speed sensor headache - JeepForum.com
post #1 of 4 Old 09-19-2013, 05:30 PM Thread Starter
Nolvck
2010 JK Wrangler
I have seen a million threads on these things but none of them have the answer to my problem. I had a code for output speed sensor so I replaced it as well as the vehicle speed sensor. I disconnected the battery to reset codes and it seemed to be fixed. Drove it down the road and light came back on and symptoms reappeared. Anyone know of a fix? Code still reads bad sensor, speedo still freaks, and it continues to stall/not shift properly. Any advice is helpful at this point. Thank you
I have a 4.0 with a 42RE...
Fluid levels are where they should be...
Nolvck is offline
post #2 of 4 Old 09-19-2013, 07:19 PM Thread Starter
Nolvck
2010 JK Wrangler
Shows code p0720
Nolvck is offline
post #3 of 4 Old 09-19-2013, 07:54 PM
ZeeJay1997
As you can see in the diagram, it's a straight shot to the PCM, middle connector.
So you've got a wiring or connector problem, a bad PCM...not likely but not out of the question, or a bad replacement sensor... even more unlikely.
Check the harness from the transmission for chaffing or damage. Then pull and clean PCM connectors.
ZeeJay1997 is offline
post #4 of 4 Old 09-19-2013, 09:21 PM Thread Starter
Nolvck
2010 JK Wrangler
I will give that a try this weekend. Do you think I can determine bad wiring with volt meter? Or do I have to just follow the wires?
Nolvck is offline
