Speaker size? - JeepForum.com
post #1 of 13 Old 02-24-2013, 07:19 AM Thread Starter
Adam86
Speaker size?
What's the standard speaker size front and rear? I need to replace mine.
Jeep has the infinity gold system incase that matters.
Thanks
Adam86 is offline
post #2 of 13 Old 02-24-2013, 07:36 AM
dusterdude
Crutchfield.com,enter your jeeps info and it will tell you
dusterdude is offline
post #3 of 13 Old 02-24-2013, 09:49 AM
9859limited
Six and a half inch front and rear. And the inifity amp is a two ohm setup for better sound bypass it.when you put in the new four ohm speakers. Or locate two ohm speakers.
9859limited is offline
post #4 of 13 Old 02-24-2013, 09:51 AM
gearheadnick
On my 97, it's 6.5 inch speakers. I went to crutchfield, verified the size, bought a pair off amazon, and put them in. They were the right size. Just make sure you don't get speakers that are too deep, or you'll have to space them out from the door.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #5 of 13 Old 02-24-2013, 11:45 AM
JeepBeats96JGC
The front and rear doors are 6 3/4.
JeepBeats96JGC is offline
post #6 of 13 Old 02-24-2013, 01:21 PM
Scopez
1994 ZJ
They're technically 6.75in shallow mount speakers. 6.5in speakers work just fine. I have 4 6.5in pioneer speakers in all my doors, and 2 6.5in JVC speakers custom fabricated into the rear hatch. I've got plenty of bass, but I'm wanting to rewire the tweeters in the dash for better highs.
What's a good tweeter for the dash without having to cut any mounting brackets?
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #7 of 13 Old 02-24-2013, 05:59 PM
um7267
this is what i have, ordered an adapter from autozone itll be here Wednesday, the 6.5 didn't fit do to the 3 tabs stilling out of the old speaker baskets if only i had a welder i could have made my own
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #8 of 13 Old 02-24-2013, 06:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
stock is shallow 6.75" components front and coax rear. they're kind of a rare aftermarket. so just get 6.5 with adapters. make sure you get 2ohm if retaining stock amp.
ratmonkey is offline
post #9 of 13 Old 03-23-2013, 09:14 AM Thread Starter
Adam86
Thanks for your input guys.
What's the difference between 2ohm and 4? Will 4ohm not work with my amp? Also what size are the tweeters?
Adam86 is offline
post #10 of 13 Old 03-23-2013, 09:46 AM
9859limited
4ohm will work with the amp but where as the amp is a 2ohm amp it will affect sound a little bit. I had the factory amp pumping four ohm speakers and when I bypassed the amp gained some volume and clarity.
post #11 of 13 Old 03-23-2013, 10:19 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
yeah, the amp will not be able to put as much wattage into 4ohm as it does the 2ohm, and it works harder to do it. so you lose some top end and clarity. most people never notice such things though.
post #12 of 13 Old 03-23-2013, 12:51 PM
9859limited
I personally didn't notice it until installing the same component speakers into my buddies non amp equipped Laredo.
post #13 of 13 Old 03-23-2013, 01:00 PM Thread Starter
Adam86
Ok thanks. I've decided on some speakers they are 4ohm so ill give them a try with the amp still connected at first. One more question though. Should l go 2 or 3 way?
Adam86 is offline
