speaker ?'s - JeepForum.com
post #1 of 7 Old 09-18-2013, 08:07 PM Thread Starter
OregonZJ98
1991 XJ Cherokee
speaker ?'s
What size speakers come in the stock 1998 jeep grand cherokee laredo v8 5.2L?
OregonZJ98 is offline
post #2 of 7 Old 09-18-2013, 08:57 PM
ejschultz
6.5" all the way around. With some modification of aftermarket brackets, you can fit a 6.75" if they're not too deep. Depth is going to be your enemy. If Crutchfield says they're not going to fit, they probably won't fit because of depth. Take their word for it.
ejschultz is offline
post #3 of 7 Old 09-18-2013, 08:58 PM
kg6mov
Hears the voices
kg6mov's Avatar
The stock are technically 6.75, 6.5's fit. Good ones come with an adapter ring and bolt right up.
kg6mov is offline
post #4 of 7 Old 09-18-2013, 09:05 PM
ejschultz
The problem with most aftermarket 6.75s is they're too deep and the Chrysler adapters generally work with 6.5" speakers, not 6.75" speakers. Chrysler speakers, even the Infinity ones, use a 3 screw mounting pattern. Aftermarket speakers mostly use a 4 screw mounting pattern. No aftermarket speaker bolts up directly without an adapter.
post #5 of 7 Old 09-18-2013, 10:45 PM
ZJNewbi3
I have 6.5" aftermarkets and I got these from Crutchfield to make them fit properly:
http://www.crutchfield.com/p_142SAC6...s.html?tp=2824
http://www.crutchfield.com/p_237XT65...h.html?tp=2809
the baffles aren't really necessary BUT they eliminate all rattle and keep the speakers dry and clean if you have those issues.
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #6 of 7 Old 09-19-2013, 07:28 AM
PolkaPower
/\ that's what came with mine from Crotchfield.
PolkaPower is offline
post #7 of 7 Old 09-19-2013, 08:14 AM
ejschultz
Mine too. I got creative and used a dremel to open them up to fit the 6.75s I have.
