Speaker Removal... - JeepForum.com
post #1 of 2 Old 01-06-2003, 03:12 PM Thread Starter
ddoffroad
ddoffroad's Avatar
Speaker Removal...
I think my '93 ZJ has a bad wire comming from a speaker and is grounding out, no sound is comming out of the deck. How do I take off the front and rear door panels to gain access to the speakers?
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad:
My XJ site:
My Old XJ Site:
ddoffroad is offline
post #2 of 2 Old 01-07-2003, 10:18 AM
automan25
The door panels actually can be removed quite easily. First off you need to remove all of the screws that hold the door panel on. I think there are about 4 or 5 of them. Two of them are kind of hidden, one in the black plastic area near the rearview mirror, and one behind a plastic plug just behind the door opening lever. Once you have all of the screws out use your fingers to slowly pry the door panel away from the metal door frame, beginning with the outside edge of the door. What you are doing here is trying to carefully remove the plastic connectors that hold the door panel in place. With some gentle force they should pop away from the frame. Work your way around the door panel along the rest of the outside edge, then the bottom edge, then the inside edge, and finally the top of the door. When you have all of the connectors free the only things holding the door panel to the door frame should be the wire connectors for the power window switch, and the courtesy lamp (you may or may not have these connectors in your jeep) Simply disconnect the wires and you're done. If you have manual windows you'll probably need a special tool to remove the window crank handle. At this point you should have easy access to the door speaker. You'll want to check all of those plastic connectors before you reinstall the door panel to see if any of them are broken. If some of them are broken, then pay a visit to a local body shop of see if they won't sell you some. Often they'll even give them to you in hopes of future business. Shucks auto supply doesn't have them, I know that for sure.
Good luck.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
95 ZJ fuel line removal & Oil filter removal Ahardy4 ZJ Grand Cherokee Forum 6 12-02-2007 02:33 PM
rear speaker removal (WJ) 99limitedWJ ZJ Grand Cherokee Forum 2 08-25-2007 11:59 AM
Speaker Removal JeepingOverYou ZJ Grand Cherokee Forum 3 05-30-2005 04:42 PM
speaker removal help jonathan98ltd ZJ Grand Cherokee Forum 5 03-22-2005 09:12 PM
Speaker Removal xTrevor ZJ Grand Cherokee Forum 1 10-04-2004 11:14 PM
