sparks?! - JeepForum.com
post #1 of 7 Old 02-17-2013, 06:32 PM Thread Starter
um7267
sparks?!
so i was wiring up my amp and subwoofers, i disconnected the negative battery terminal to wire the positive in and after i disconnected it the rem and 12v source wires touched what i believe to be the back side of the ac compressor. not really sure because i was still moving the ground to a place it wouldn't wiggle loose then all of a sudden sparks...
shortly after(kind of worried about it but nothing seemed abnormal) it wont start cranks but the i did have the doors open for the past 2 days while doing it, put it on a charger and it started but the distributor is making noises. however i already new i need to replace the unit sometime.
im leaning toward the fact that it is 10 degrees outside and i killed the battery, but at the same time it is a month old ever start with 850 cold cranking amps, other factors are that i haven't driven it in 2 weeks, i have started it up to move it in the garage and once more to angle it so i could open the doors.
so dead battery or something worst? i did check the fuses under the hood and they seemed fine
thanks in advance
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #2 of 7 Old 02-17-2013, 06:35 PM
xtremzj
Sounds like you answered your own question.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #3 of 7 Old 02-17-2013, 07:13 PM Thread Starter
um7267
so i riddled myself? dang it i guess its just nice to have a place to type out my thoughts, so best case its a dead battery, is it possible to short the starter out like that? this is about the 10th system i have done not a pro by any means but i know enough, but never had the system store power before either
um7267 is offline
post #4 of 7 Old 02-17-2013, 09:16 PM
ZeeJay1997
What is a rem?
ZeeJay1997 is offline
post #5 of 7 Old 02-17-2013, 09:53 PM
sebian
I assume remote amp wire since he is installing a stereo.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #6 of 7 Old 02-18-2013, 08:07 AM Thread Starter
um7267
yes rem as in remote, not rapid eye movement ha, but wire a toggle switch vs running it off the head unit. the head units have the same ability to turn it on and off but it is a pain to find the setting in the unit if the manual is lost like mine( dang po)
but it is supposed to be 40 today so ill try to start it up, it was on a charger all night so we will see, maybe ill take the battery to walmart and exchange it for a new one if it does not work
um7267 is offline
post #7 of 7 Old 02-18-2013, 06:10 PM Thread Starter
um7267
the good news is that is lives and the other is that after some more research the pcm does need to learn how to idle so after got it started and left my foot on it for about 5 minutes it stayed running, just in case anyone else searches and finds this thread looking for answers to a drained battery
um7267 is offline
