Which sparkplugs for my Jeep? - JeepForum.com
post #1 of 26 Old 07-05-2009, 04:16 PM Thread Starter
Bowlerguy92
*I have a 4.0L STR6 in a 99' JGC Laredo* I have searched and found a useful thread on sparkplug recommendations but through many conflicting viewpoints I would like to verify that opinions haven't changed in 2 years...so I heard that Champion "Truck Plugs" are "best" for the Jeep. I also saw these Iridium ones here Is the $4 price hike worth it or should I just go with the truck plugs? I can find the Champion truck spark plugs in any autoparts store too correct? Also, should I change the coil and boot from the coil rail each time I change spark plugs too? Or can I just add spark plugs and slap the rail back on?
Thanks!
Bowlerguy92 is offline
post #2 of 26 Old 07-05-2009, 09:44 PM
jeep95xj
1995 XJ Cherokee
99 STR6? You sure about that? I dont believe there is such a thing.
jeep95xj is offline
post #3 of 26 Old 07-05-2009, 09:55 PM
1997ddzj
srt= straight 6
When i did mine i just bought some regular $1.50 plugs. Gaped em and never had a problem
1997ddzj is offline
post #4 of 26 Old 07-06-2009, 04:59 AM
Turbonut
Replace with the factory plugs.
Turbonut is offline
post #5 of 26 Old 07-06-2009, 08:09 PM
sbxj
sbxj's Avatar
what is the factory plug?
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #6 of 26 Old 07-06-2009, 08:10 PM
the88thpianoman
2003 WJ
Cheap, simple champion copper core, or cheap simple autolite copper core.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 26 Old 07-06-2009, 08:21 PM
Unka-Boo
I like No Good Kind, with Autolite as my 2nd. They did however, come with Champion from the factory.
Unka-Boo is offline
post #8 of 26 Old 07-06-2009, 08:28 PM Thread Starter
Bowlerguy92
So I won't notice any difference by going to more expensive plugs?
post #9 of 26 Old 07-06-2009, 08:29 PM
the88thpianoman
2003 WJ
None whatsoever. Occasionally fancier plugs will even cause problems on the 4.0 and are guaranteed to on the 4.7.
post #10 of 26 Old 07-06-2009, 08:30 PM Thread Starter
Bowlerguy92
Alright then that saves me some money! Also, should I change the spring and boot with the plugs or are those good? 6 of them cost like $40 by themselves so I really don't want to have to. Thanks for the suggestions!
post #11 of 26 Old 07-06-2009, 08:34 PM
sbxj
sbxj's Avatar
What about for the 4.0 with distributor-less ignition. What does the Dealer install? I want to use the same plugs because the Jeep has run flawlessly since being serviced at 55k.
oops wrong forum
'01 XJ 2DR Sport
sbxj is offline
post #12 of 26 Old 07-06-2009, 08:55 PM
the88thpianoman
2003 WJ
No need to unless you have a misfire. The I6 ignition coil is an excellent and efficient system.
oops wrong forum
Same champion copper core plugs. If you want to be sure of what the dealer actually put in, though, just pull one and look at it.
post #13 of 26 Old 07-06-2009, 09:09 PM
MEinSoCal
if you want the peace of mind, you can always buy the champions from the stealership for a premium
MEinSoCal is offline
post #14 of 26 Old 07-06-2009, 09:10 PM
xJoshxx
2012 WK
I put cheapo autolites in jeep loves em
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #15 of 26 Old 07-07-2009, 10:49 AM
the88thpianoman
2003 WJ
Same here, actually. However, I'm tempted to try the autolite platinums, figuring they might last longer than the copper. Normally I wouldn't bother, but we have them on sale at work for only 20 cents more per plug than the copper. Anyone else use these?
ZJ 5.2 best sparkplugs? joegooding ZJ Grand Cherokee Forum 19 07-29-2014 09:04 AM
Couple repairs planned for this weekend, will my Jeep be right by monday jeep gods ?? cherokeeghost ZJ Grand Cherokee Forum 1 11-12-2008 11:53 AM
ZJ 4.0 engine oil and sparkplugs james157 ZJ Grand Cherokee Forum 9 12-03-2007 03:27 PM
