which spark plugs for wj's best preformance ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > which spark plugs for wj's best preformance ?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-15-2009, 01:29 PM   #1
genislav ronen
as writen ,
1999 v8 4.7 wj ,
with superchip ,
would like to get the best spark plug for my wj's best preformance .
what do you recomend ?
thanks
ronen
1999 WJ /IRO 6" C.Path LA F&R /clayton's 4 linked rear end /D30-ARB /D44A- Aussie'd /Chromoly U-Joint F.Axle /242hd /4.10's /FOX 2.0 shocks /JKS shock adapters /F.Adj T.Bar /HD double SS/Pitman drop kit /T.Woods F.double cardan d.shaft +pinion yoke&TC yoke /265/75/16 bf mt /Solid HD dana 30 cover/Double open air fillter/ black rock 4" bs /Lower F+R C.Spring Retainers /4" front B. Stops /SUPERCHIP /Addco Rear HD Sway Bar /Rock Sliders /T.case skid plate /HAYDEN hd gear radiator
genislav ronen is offline   Reply With Quote Quick reply to this message
Unread 03-15-2009, 05:13 PM   #2
Turbonut
Ignition is one of the hardest items to improve upon, so just stick with the factory OE plugs.
Turbonut is offline   Reply With Quote Quick reply to this message
