spark plugs 99 gc - JeepForum.com
post #1 of 8 Old 12-14-2008, 03:54 PM Thread Starter
tattoocharger
spark plugs 99 gc
is there a write up with pictures somewhere???? always used to vehicles with spark plug wires, not used to this newfangled crap
tattoocharger is offline
post #2 of 8 Old 12-14-2008, 04:11 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Plugs are the same as they've always been....just have coil packs on em now.
Grab the CP, yank em off, there's yer plugs....
'09 Rubicon
Kruzin is offline
post #3 of 8 Old 12-14-2008, 07:45 PM
cmonson
Coil packed plugs are even easier to change (no wires to deal with). Cheaper as well, as most of the time the coil packs last forever (knock on wood) and you don't have to replace wires as part of a tuneup.
cmonson is offline
post #4 of 8 Old 12-14-2008, 08:43 PM
txtumbleweed
Read All About It - And Bookmark the HomePage
http://www.wjjeeps.com/service/sparkplugs.htm
Y2K WJ 4.7
txtumbleweed is offline
post #5 of 8 Old 12-14-2008, 09:07 PM
mailforjon
mailforjon's Avatar
2005 WK
the coil packs and plugs on the 4.7 are a nightmare to replace. especially on the rear passenger side. they might be considered "cheaper" if you buy the generic packs at autozone or where ever, but i think they are about $40-$50/each if you get a genuine mopar coil pack. multiple that by 8, and thats quite a bit more than any set of premium wires ive ever bought.
regardless, if you are swapping out plugs/packs, be very careful pulling the coil packs out. when i replaced mine at 115k (and im not sure if they had ever been done before that), they were seized in the cavities pretty badly. i ended up accidentally cracking the bottom part that surrounds the spark plug on several of them. this process was even more tedious on the rear passenger side.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #6 of 8 Old 12-14-2008, 11:03 PM
20jeepwj00
To change the 4.7 plugs,remove the air intake at the throttle body,remove the 10mm bolt holding the oil dipstick tube and bend it slightly out of the way,using a screw driver lightly push down on the locking tab on all the coil pack connectors and pull them off,remove the 10mm bolts on each coil pack and pull up on the coil to remove it,ive found the easiest way to remove the plugs is with a 5/8 swivel plug sock and and extension,the rear on the pass side is a little tircky,but everything usually comes apart without problem.
20jeepwj00 is offline
post #7 of 8 Old 12-15-2008, 12:33 PM
cmonson
The I6 is very easy to change and all plugs are very easily reached. The V8 is a different story.
cmonson is offline
post #8 of 8 Old 12-15-2008, 12:50 PM
JG_Canuck
^on the 4.7L, the rear plug on the passenger side is the only one that presents any "difficulty". All the rest are very easy to get to.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
Which Spark Plugs to run...???? 1badjk WK Grand Cherokee & XK Commander Forum 14 09-26-2009 11:15 AM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 07:17 PM
WJ Spark Plugs FlipFlop425 ZJ Grand Cherokee Forum 19 10-14-2007 07:11 PM
Spark plugs??? Diehard ZJ Grand Cherokee Forum 16 07-25-2006 10:03 PM
Spark Plugs Othoni ZJ Grand Cherokee Forum 4 04-24-2005 10:12 PM
