Spark Plugs - JeepForum.com
post #1 of 13 Old 11-20-2005, 08:20 PM Thread Starter
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Spark Plugs
Well I got a suprise today. I am planning on changing my plugs so I got out the service manual (OEM) to see what Champion plugs I needed. Suprise, suprise, the 04' manual recommends NGK #ZFR5N gapped to .040. I checked the manual for the 00' Cherokee and it said Champion RC12ECC gapped to .035. I think I will go with the Champions.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #2 of 13 Old 11-20-2005, 08:53 PM
oct7brian
oct7brian's Avatar
Just slap some Champion Truck plugs in there Everyone seems to love them
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #3 of 13 Old 11-20-2005, 09:13 PM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
What number is the truck plug?
Lifetime member #13
post #4 of 13 Old 11-20-2005, 09:21 PM
WVZJ
I ran the NGK's in my 5.2 with great results. No complaints here. Just stay away from the Bosch Platinums.
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #5 of 13 Old 11-20-2005, 09:31 PM
CanadianZed-J
I just put replaced my (worn) Champians with some Bosch Platinum 2s. Unfortunately you can't get the Platinum 4 for the 4.0.
I noticed a night & day difference Platinum 2s and the old Champions (I'll say again they were worn.). Fuel economy stayed the same, but it ran smoother and sqauked the tires a little easier too.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #6 of 13 Old 11-21-2005, 08:26 AM
det69
I just changed mine as well. The sticker under the hood stated to gap them at .035 and so did the info I found at www.wjjeeps.com. Wonder if I need to regap them? Mine also had NGK plugs from the factory.
04 GC; I-6
det69 is offline
post #7 of 13 Old 11-21-2005, 08:46 AM
vosevichs
What's wrong with the Bosch Platnium's??????
vosevichs is offline
post #8 of 13 Old 11-21-2005, 08:59 AM
FPKites
ZJjazzyJim
FPKites's Avatar
NGK all the way here. I've got 'em in my 5.2, and had them in my 4.0 (XJ). Vos, the Bosch Platinum discussion was earlier...some people don't like them because of the little bit of extra voltage they need. Some have seen their coil strain a bit.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #9 of 13 Old 11-21-2005, 09:04 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Yeah the Bosch's need a high power coil otherwise they have a weaker spark than most other plugs out there. They also caused the stock coil to kick twice in my Trans Am. When I put a larger Accel coil in the T/A it worked great. I would run bosch's again only if I put a big coil on. I don't feel like doing that with my GC, as I have other money needs in it.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #10 of 13 Old 11-21-2005, 10:28 AM
OlllllllO Jeep1
I remeber reading somewhere on the YJ side, a discussion of people saying not to use platinum plugs with the 4.0. So is this this reason that you guys are talking about that platinum would need a higher performance coil to fire at their max voltage?
Well anyway I seem to remember Forum guys also saying that the 4.0`s seem to like Autolite plugs. I cant really see what the reason for this. Although I did throw a set of Autolite Copper plugs in my 4.0 ZJ and it doesnt seem to run any differnt than the Champions that were in there.
Then again I dont know if those plugs are new or not, seeing that my 97 has 48k original. I would seem to think that they were probably never changed, so I went ahead and changed them.
OlllllllO Jeep1 is offline
post #11 of 13 Old 11-21-2005, 10:57 AM
greasefingers
greasefingers's Avatar
1994 ZJ
When I brought my ZJ into the dealer for a re-man tranny, I found my newly installed Bosch plugs on the passenger side floor in a ZipLoc baggie. When I asked why they remove a set of plugs that were only three months old, they only stated that they do not recommend them. They replaced them with the regular Champion plugs.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #12 of 13 Old 11-21-2005, 12:07 PM
nashmd454
nashmd454's Avatar
Hey Woody, I used to run the Bosch like a ritual but once I got Nick's ignition upgrades I also changed to plain ole Champions. I am now curious that since my coil is an upgrade to MSD with 8.5 Magnecor wires...what is the best plug. I used to run the stage 2 jet chip and ran a colder plug but man she sucked on gas so I have since taken the chip out and so forth.
Doug
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #13 of 13 Old 11-22-2005, 09:25 AM
Woody
Woody's Avatar
1985
I like the Champion truck plugs. I have yet to see a spark plug that give an advantage over another though.
Woody
Woody is offline
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
spark plugs 99 gc tattoocharger ZJ Grand Cherokee Forum 7 12-15-2008 11:50 AM
WJ Spark Plugs FlipFlop425 ZJ Grand Cherokee Forum 19 10-14-2007 06:11 PM
Spark plugs??? Diehard ZJ Grand Cherokee Forum 16 07-25-2006 09:03 PM
Spark Plugs Othoni ZJ Grand Cherokee Forum 4 04-24-2005 09:12 PM
