Spark Plugs - JeepForum.com
post #1 of 5 Old 04-24-2005, 06:44 PM Thread Starter
Othoni
Spark Plugs
Today I wanted to do a tune up to my jeep.I went to autozone and got "6 Champion truck plugs part#4412. I took off the coil rack and took out one spark plug and tried to match it with the champion plugs I bought, the champion plugs are longer then the plug I took out of my jeep. Should I use the champion plug even though its longer then the plug I pulled out or should I get a different plug?
00 WJ I6 4.0L 4x4,
FIPK Gen2,Borla Exhaust Magnaflow tip, Carsound Cat, 62mm TB,Alarm/Remote start,Tinted windows,Front and rear tow hooks,Hypertech programmer3. Addco rear and front sway bar, Hid's 8500k
Othoni is offline
post #2 of 5 Old 04-24-2005, 08:37 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Just check and see if those are the correct ones. I don't know for sure. Someone could've put the wrong ones in last time. Your emissions label should say which plug to use, and just cross it over to the Truck plug. I will be putting those in my Jeep this summer at my next oil change. Great plugs, had them in everything and they work wonders!
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 5 Old 04-24-2005, 08:57 PM
askoop
I've got Champion trucks #4412 in my 2000 WJ I6 and they work just fine... but they were the same size as the OE ones I took out...
Great plugs! Especially for the price.
-Adam
His: 2000 WJ, 2.5" BB, mx-6 shocks, Rancho 5000 Steering Stabilizer, 245/75/16 MTRs, 1" addco rear sway bar, 9005 fog upgrade
Hers: 03 KJ, 5-speed, 245/70/16 General HTS
WTB: 1 Timberline wheel or a set of JK steelies
askoop is offline
post #4 of 5 Old 04-24-2005, 09:00 PM
askoop
Found this for ya...
champion plug selector
hope this helps!
-Adam
askoop is offline
post #5 of 5 Old 04-24-2005, 09:12 PM Thread Starter
Othoni
When I pulled out a spark plug from my WJ I compared it to the new spark plugs I got, there almost indentical exepct that the serial number on my old plug is "RC12MCC" as the serial number on my new spark plug is "RC12ECC" both old and new plugs are Champions. Both plugs are the same length but the gap and center electrode on the new plugs are longer then my old plugs.
00 WJ I6 4.0L 4x4,
Othoni is offline
Which Spark Plugs to run...???? 1badjk WK Grand Cherokee & XK Commander Forum 14 09-26-2009 10:15 AM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
spark plugs 99 gc tattoocharger ZJ Grand Cherokee Forum 7 12-15-2008 11:50 AM
WJ Spark Plugs FlipFlop425 ZJ Grand Cherokee Forum 19 10-14-2007 06:11 PM
Spark plugs??? Diehard ZJ Grand Cherokee Forum 16 07-25-2006 09:03 PM
