Spark Plug Preferences - JeepForum.com
post #1 of 24 Old 09-24-2009, 05:30 PM Thread Starter
Andymack
Installing Champion Double Platinum spark plugs tomorrow.
What brands do you guys use? Are the Bosch 4-prong platinum plugs any good?? I've heard mixed reviews.
What other electrical system mods do you recommend??
- = AnDyMaCk = -
Andymack is offline
post #2 of 24 Old 09-24-2009, 05:34 PM
ZJWally
from what i've seen posted around here, platinums dont work well....at least for the 4.0's. I just changed with the standard 1.99 plugs and things are running good. Ive heard of bad gas mileage and misfires after installing platinums.
ZJWally is offline
post #3 of 24 Old 09-24-2009, 05:39 PM
99avant
Skip
Get the regular champion copper truck plugs
Platinum plugs will do nothing for your 4.7
It was tuned to run on the regular copper plugs
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #4 of 24 Old 09-24-2009, 06:02 PM
96ZjBurner
bosch iridium FUSION there the best plug on the market. thats what i got in my truck. there beast. PERIOD.
96ZjBurner is offline
post #5 of 24 Old 09-24-2009, 06:04 PM
Turbonut
As long as the current plugs are firing, no spark plug will increase the performance or fuel mileage, so stick with the factory plug. With the current ignition system, no improvement needed.
Turbonut is offline
post #6 of 24 Old 09-24-2009, 06:52 PM
dougy147
Another vote for factory plugs.
My personal opinion is to stay away from the bosch platinum 2 and +4. I put these in my 4.0 ZJ and the thing never ran right, or up to temp. Installed some NGK and it corrected the problem. I used to work at an Advance, and I noticed that those particular plugs have very few part numbers compared to the application range. Almost like they just decided if the seat type, thread and length were OK it would work. Other plugs have many more part #'s for different heat ranges. Just my
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #7 of 24 Old 09-24-2009, 08:23 PM
LordHobbit
I like champion and ngk the best. If you aren't running advanced ignitions, then use regular copper. Try to stay away from Autolites, they are good plugs don't get me wrong, but they don't work so well in mopar engines.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #8 of 24 Old 09-24-2009, 08:46 PM
xJoshxx
xJoshxx's Avatar
2012 WK
mybe in your 93 but in my 00 WJ 4.0 autolite XP's i gained 2mpgs
but others were also gapped like .80
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #9 of 24 Old 09-24-2009, 09:37 PM
wickerham
..copper..
wickerham is offline
post #10 of 24 Old 09-24-2009, 09:41 PM
JrMechanic
Autolite 3923's. They are two heat ranges cooler IIRC than the factory 5224's and are well regarded in the ram/dakota world with Magnum series engines, including the 3.7 and 4.7.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/n...pdated-685644/
JrMechanic is offline
post #11 of 24 Old 09-25-2009, 06:16 AM
melloyello
best or most expensive thing you could find?
melloyello is offline
post #12 of 24 Old 09-25-2009, 06:17 AM
melloyello
Had nothing to do w/ the brand of plug. Gap was twice what it was supposed to be.
post #13 of 24 Old 09-25-2009, 07:15 AM
floridajpr
2015 JK Wrangler
I dont think that Champion makes the truck plugs anymore. I went to their web site and they are not listed and everyone I ask says they are not producing them anymore. I went on the web just a few weeks ago and finnally found 2 boxes(12) of the Champion truck plugs but the auto parts store said that they are going to be the last as they are not making them anymore.
floridajpr is offline
post #14 of 24 Old 09-25-2009, 08:02 AM
xJoshxx
xJoshxx's Avatar
2012 WK
my point exactly doesn't matter on the plug it will be better than the one u had
2011 WK2 ORA2 sold
xJoshxx is offline
post #15 of 24 Old 09-25-2009, 09:20 AM Thread Starter
Andymack
I put the double plats in - they are Champion and they're practically identical to the NGKs that I pulled out of it.
They don't seem to perform any differently. A little more gradual warm-up, a little less rough on start-up, and better response when shifting so it's like riding a cloud.
Next, I'm gonna get some UpCountry suspension and a BB, then whacky exhaust.
Thanks guys, I'll let you know if these plugs are crap in a few weeks.
- = AnDyMaCk = -
Andymack is offline
Best spark plug for 5.2L -cAcHe- ZJ Grand Cherokee Forum 17 01-19-2010 09:27 PM
WJ spark plug help joee0914 ZJ Grand Cherokee Forum 4 01-09-2009 12:39 PM
NGK spark plug gap drespecki ZJ Grand Cherokee Forum 2 12-10-2008 07:58 AM
Spark plug effort level & plug recomendations Bville-Bud WK Grand Cherokee & XK Commander Forum 3 11-26-2008 01:02 PM
Spark Plug Gap? 95JpGC ZJ Grand Cherokee Forum 11 01-04-2007 04:43 PM
