Spark plug heat shields - JeepForum.com
post #1 of 3 Old 12-29-2003, 12:51 PM Thread Starter
Meerkat
Went to do a tune up on my 96 5.2 and discovered these little heat shield thingies that keep my handy dandy spark plug removing socket from reaching the plug. Is there some secret to removing them, or do I need a thin-walled 5/8" socket? I did try twisting and wriggling one, but it seems to be pretty firmly entrenched. I thought before I get the hammer I would check on here for suggestions. Thanks!
Just re-examined the socket, and there is no thinner walled one than what I have, so it stands to reason these things have got to come off. Haynes is oblivious, so I am relying on somebody here to give me the inside scoop.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #2 of 3 Old 12-29-2003, 02:54 PM
Swamp Boy
Swamp Boy's Avatar
maybe its bent or something mine came out ..No problem..
Good luck..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 3 Old 12-29-2003, 03:18 PM Thread Starter
Meerkat
Good luck..
Thanks, I just talked to the fellers down at the local tune 'em up place, and was told they are a friction fit and should pull straight out with pliers. It helps just to know they aren't threaded in or have lock screws. I got the rotor, cap, and wires changed (my arm is bleeding nicely) so I figure I'll do plugs tomorrow, or maybe the day after, or maybe next week....
Thanks for the info!
Warren
Meerkat is offline
spark plug gap mbquart ZJ Grand Cherokee Forum 8 09-01-2009 09:16 PM
Spark plug effort level & plug recomendations Bville-Bud WK Grand Cherokee & XK Commander Forum 3 11-26-2008 01:02 PM
Exhaust Heat Shields EmpireTroy WJ Grand Cherokee Forum 15 08-08-2007 01:47 PM
bad spark plug??? H2RecoveryTeam ZJ Grand Cherokee Forum 9 07-24-2007 10:28 PM
Spark Plug Gap? 95JpGC ZJ Grand Cherokee Forum 11 01-04-2007 04:43 PM
