spark plug diagnosis - Page 2 - JeepForum.com
post #16 of 32 Old 08-03-2009, 11:46 PM
Virmagicus
Virmagicus's Avatar
Yes ... Champions will last the longest, have the best performance, and will be the least problematic out of all of the other plugs. Some may argue, but they don't know ****
Jeff
Virmagicus is offline
post #17 of 32 Old 08-04-2009, 06:19 AM
malibubts
Put in some Champions just last week! I'm running great with no problems at all.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #18 of 32 Old 08-04-2009, 12:46 PM Thread Starter
cloiselle
this has gone from spark plug diagnosis to all hail the CHAMPIONS thread.
cloiselle is offline
post #19 of 32 Old 08-04-2009, 02:20 PM
JrMechanic
It's in your head. You did not see any performance increase from changing those plugs out, unless one of them was defective.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #20 of 32 Old 08-04-2009, 02:48 PM
malibubts
Champion.
No really, I just put them in because it was my first plug change and that's what Jeep recommends.
post #21 of 32 Old 08-04-2009, 02:55 PM
taythegibs
when i got my zj it missfired like crazy, i replaced them with some good ole champions and now it never misses and ive got loads more power, of course my plugs were 5miles from being non-existent......
taythegibs is offline
post #22 of 32 Old 08-04-2009, 03:29 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
According to Horsepower TV, E3s give more hp and burn less gas. Proven by their dyno and measuring equip.
HighLonesome is online now
post #23 of 32 Old 08-04-2009, 04:08 PM
JrMechanic
I call BS on any claim like that. While it's a possibility that they may increase power, whatever increase that is will be marginal and the other variables involved (ambient air temperature, who's doing the dyno pull, etc) will overcome it, so it's impossible to say they provide more power and better mileage.
Basically, a spark plug is a spark plug. The only real benefit to a platinum/iridium plug is the longer life, and they are more durable when used in applications with high voltage ignition systems. The multi tipped plugs are a joke, everyone knows that electricity takes the path of least resistance to ground. Meaning, that if say you have say a 3 tip plug, unless you have all three tips gapped EXACTLY the same, the charge will arc to the closest tip.
A copper plug gapped correctly will provide the the least troublesome operation life. I prefer Autolite copper cores over Champions because of some bad experiences with Champion plug construction, but when gapped at regular intervals, either will work very well in just about any car.
post #24 of 32 Old 08-04-2009, 04:19 PM Thread Starter
cloiselle
i didn't seen any performance increase,
but i did regain fuel economy and throttle response lost due to a change in heat range ( from 11 to 12, off par back to oem) and new plugs.
the numbers don't lie, not using the dope scope to get my mpg, good old pencil + paper and math.
i find it rather ignorant to say that a simple change in plugs wouldn't net you a more efficient spark and combustion sequence. especially from a " junior mechanic "
oh teh interwebz...
that's almost as ignorant as saying a new air filter, fuel filter, cleaned throttle body, new o2 sensors , exhaust system or coil packs wouldn't return your engine to it's most efficient state of operation. i'm not a mechanic by any means. but i am a scientist by trade. any means of transfering power, in or out of an engine that is restored to it's original state has a equal effect on productivity of power.
newton son.
every action........... you know.
post #25 of 32 Old 08-04-2009, 04:26 PM
Virmagicus
Virmagicus's Avatar
Yup
Jeff
post #26 of 32 Old 08-04-2009, 07:22 PM
JrMechanic
oh teh interwebz...
newton son.
Well you might not be a mechanic... But I am. And unless there is something wrong with the plugs, the air filter, fuel filter, exhaust system or coil packs, you will not see any performance and or mileage increase by changing them. Only thing you will see is a dent in your pocket.
Btw, aren't you the one that claimed something like 27mpg out of your 4.7?
post #27 of 32 Old 08-04-2009, 08:17 PM Thread Starter
cloiselle
i averaged 26.4 mpg on a trip from kankakee to dwight IL, reseting my dope scope after filling up and ending it when i pulled into the parking lot of where i was going, that was after new plugs, filter, oil , coils and adjusted air pressure.
guess you zj boys don't know much about a more efficient and productive engine or how to light foot it for a whole trip. i touched the brakes once, and that was when i pulled into the parking lot at my destination. 55mph the whole way was a buzz kill but i kept it groovy baby ;0) a little hendrix through the infinities to boot. it was like 1974 all over again.
post #28 of 32 Old 08-04-2009, 08:29 PM
Katesdad
Katesdad's Avatar
Autolites are great plugs I like them alot. But they should be lasting 40-50k so you cranked the air pressure lol
Reddick Red **** my fav town name on 17.
Katesdad is offline
post #29 of 32 Old 08-05-2009, 05:01 AM
kentman
kentman's Avatar
2006 XK Commander
I assume that he is referring to the fact that a dirty air filter results in a higher air pressure pressure drop across the filter. The higher pressure drop will result in a slower velocity of the air across the filter. With a clean filter, that means that there will be more air per unit time and thus more O2 for complete combustion per unit time. Makes sense.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #30 of 32 Old 08-05-2009, 06:16 AM
Katesdad
Katesdad's Avatar
40 psi (or higher) offers lower rolling resistance than 34psi also. Besides thats a 30 mile trip hardly something thats going to tell the real story.
Katesdad is offline
WJ Spark Plug Diagnosis & Replacement (w/ pics) mailforjon WJ Grand Cherokee Forum 36 02-15-2012 04:46 PM
spark plug gap mbquart ZJ Grand Cherokee Forum 8 09-01-2009 09:16 PM
WJ spark plug help joee0914 ZJ Grand Cherokee Forum 4 01-09-2009 12:39 PM
Spark plug effort level & plug recomendations Bville-Bud WK Grand Cherokee & XK Commander Forum 3 11-26-2008 01:02 PM
spark plug help me! TheAngus ZJ Grand Cherokee Forum 3 09-20-2006 07:33 PM
